Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Alternative method - Compose and render the scene first without the figure. Apply the render to a one-sided square primitive and position to fill the screen in exactly the same aspect as the original. Set the square to partial transparency in whatever percentage suits your purpose - try 50% and adjust as needed. Place the figure where you want it, and re-render with the semi-tran parent scene superimposed over the figure. Might produce the effects you want, with a bit of trial and error. Good luck with your image. . .
Yup, Poser does really strange things when you make a figure semi-transparent. Worst of all is that parts like ears and noses can show up at weird angles, because they're seen "from inside" which throws Poser into a confused tizzy. The only decent solution, as the other answers said, is to render the object by itself, opaque as usual, then use 2D layers to put it back into the scene with transparency. You might want to mix a white mask onto it as well.
My python page
My ShareCG freebies
Attached Link: Davey Jones Ghost
You could also try Davey Jones Ghost at DAZ which has a ghostly transparent figure http://www.daz3d.com/shop.php?op=itemdetails&item=1697Attached Link: http://www.weirdass.net
Use the grouping tool to apply a new material to the internals of the head. MitchThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I am trying to make one of the figure transparent. Everything is fine, until I try to do this to the head. When I go to make head transparent, You can see all things inside the head. Gum, teeth, etc. It looks awful. So I go and make all the rest of the stuff even more transparent, but doesn't really help much. Is there a way to make these parts invisible? I don't see anywhere to do so like you can with all the rest of the props. I am using P6 if that makes any difference. Please help if you can! Thanks!
