Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
It's a vertex order problem, but I guess you knew that... ;) UVMapper Pro can also do vertex re-ordering, if you have that. It isn't always successful. Other than that, it's just down to care during the export and modelling process. With a leetle more information about how you got here from there, we can perhaps suggest an alternative route...
But all I did was actually to export the head out of Poser, delete something in UVMapper, reimport it and merge it with a new version of what I deleted and apply it. Hmm.. I DO have UVMapper Pro (Thanks to Dr Geep ::o)) ) I'll try that to see if it does a better job than Poser. :o)
Attached Link: Riptide Plugin
what app you use to make the morph? if you use Cinema 4D then I think I know what the problem is: C4D reorders the vertex ... you need to import with a free plugin: Riptide (made by Spanki) www.skinprops.com Maybe that helps :) Greets Chris"It Is Useless To Resist!" - Darth Vader
LOL Well, I thought I'd got a good idea. As it became obvious from yesterday's thread, ther's a problem with AIKO's HdFaceCheeky morph, making her teeth all crooked and unpleasant looking. So my initial idea was to export the Cheeky morph together with some normal teeth and merge those two, thereby making a new morph that would give the cheeky (wide) face but retain the normal looking teeth. But I can't make it work. The morph loads fine (nothing about "wrong number for vertecis or anything) but when I apply it, it explodes. I've tried both deleting the various bits in UVmapper as well as using Poser's grouping tool to spawn new head without teeth and new teeth. But as soon as those are merged onto one obj it gets screwed up :o( I thought I'd got a good idea, but... :o( Any ideas why it won't work? Why are the vertices jumbled? the morph works fine before the merge.
The problem occurs when you remove some of the mesh - when you do that, some of the vertices are removed also, and the rest of them "close up" to fill the gap. From that point on, you're in trouble. :) Although you then put back an equal number of vertices, they're put at the end of the list, not where the old vertices were taken from. Hence your vertices are out of order. Poser won't complain, because you have the right number; but when you move the dial, the delat which used to refer to her nose (for example) is now part of her ear, and chaos ensues. If you could somehow put the new vertices back exactly where the old ones were taken out, it would work; but I've no idea how to accomplish that. :(
Ah of course. It makes sense. And I guess in THEORY it would be possible to put the lines in where they belong, but probably NOT worth the hassle. Oh well. So much for good ideas LOL
Attached Link: http://ockhamsbungalow.com/Python/GroupToMorph2.zip
Ockham has a Python script that will create a new morph based on grouped polygons. This allows you you to do the whole thing in Poser without any exporting whatsoever. See link :)Oooh! That sounds interesting! I'll give it a try! Thanks R_Hatch!
I came across this thread while looking for something. While your result wasn't intentional, it looks pretty cool.
say." - Ghandi
Looks like you tried to do the changes of the mesh in Shade. If this is the case, it is a Shade problem. I reported this weeks ago and e-frontier answered that they are working on it but until now there is no result. The crazy thing is, it doesn't happen with all meshes but when, it happens even with unmodified meshes, means export from poser - import in shade - export to poser and you have this result!
Ulli
No it wasn't shade, I hate that program to be hinest. I can't really remember which program I used, could have been Blacksmith, and I THINK it was, but my usual program of choice is Max. Hehe yeah it would look good with a flame texture. Unfortunately I don't think I saved it... and you can never replicate something like this when you WANT to ;o)
