Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 9:59 am)
for a post-work solution I have used successfuly the glass filter in photoshop to achieve this look. I would copy the image to a new layer, apply this filter with whatever degree of smoothness seems appropriate, then I would mask out the parts that should not be affected, and then play with opacity levels till it looks right. Rawn
My python page
My ShareCG freebies
Attached Link: http://ockhamsbungalow.nstemp.com/MiscProps/Exhaust.zip
Here's the PP2 file, if you want a starting point.My python page
My ShareCG freebies
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1093857&Start=1&Artist=deci6el&ByArtist=Yes
Here's an example of the glass filter in Photoshop when I needed some air turbulance. It's fine for a single frame. If you're doing an animation you'll need to go to After Effects or something like it. I would Always recommend using some kind of 2D noise displacement over trying to do this with particles as the time investment for similar results would not be worth it. (IMO)Another way to do it is get SteamZ from DAZ it is one of the new prop sets from JPeter (Jepe), this or ThrowZ could most likely help you. A new set called FlameZ is due out anyday now, they are easy to use, and will give you exactly the effect you want without muss or fuss. Just a thought. Antonio
Greetings from Germany
ProFotograf
My
PoserAddicts
Specifically, I'm trying for the effect under a VTOL aircraft on landing or takeoff. Preferably within Poser, but postwork tips would be gratefully received as well.
I've tried searching for 'haze' and 'exhaust' in the forums, but haven't come up with much.
Thanks.
Message edited on: 01/03/2006 09:43
