Sun, Feb 9, 8:06 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: what's the best thing to do about daz corneas please?
  • 1
  • 2
estherau ( ) posted Wed, 25 January 2006 at 8:56 PM · edited Sun, 09 February 2025 at 1:36 AM
They look fine if the iris texture is used as in poser but then you can't dilate the pupil. Should I just make a cornea material? Has anyone got a good one they want to share. I don't actually know how to create a material in carrara anyway. Love esther
MY ONLINE COMIC IS NOW LIVE
ren_mem ( ) posted Wed, 25 January 2006 at 10:59 PM
I don't think you are going to be able to make a pupil dilate. I suppose you could make a shape you could constrict. Making a texture with different pupil sizes would probably be better.Easiest might be altering the pupil of an already existing texture or creating a texture that would go over that part of the eye to look like a smaller pupil.
No need to think outside the box....
    Just make it invisible.
estherau ( ) posted Thu, 26 January 2006 at 8:20 AM
Oops I didn't explain that properly. The cornea is that clear transparent layer over the front of the coloured (iris) part of the eye, so as long as it's transparent the iris and dilating pupil will show through just fine. It's just a matter of making the cornea look real ie sort of wet and glassy looking. I dunno quite how to explain it but if you look at someones eye from the side you will see. Poser people handle itin poser by either making the cornea same colour as iris, or making it completely transparent. If you make it completely transparent you loose the rounded look of the cornea. However in carrara there is the possibility of having a real looking cornea. Love esther
enigmaticredfrog ( ) posted Thu, 26 January 2006 at 10:48 AM · edited Thu, 26 January 2006 at 10:51 AM
What I do for the corneas if I've imported it as a pz3 files is just put the alpha on the corena so it's transparent but leaves the highlight on it to make for a more realistic cornea. I can post a screen shot of my shader settings for the cornea if you'd like
Message edited on: 01/26/2006 10:51
Christina -- "Love me but don't tell me so" Lilly Bart
My Art
sfdex ( ) posted Thu, 26 January 2006 at 12:18 PM
I'm not a poser person, really, but here's a thought that you might be able to work with. One of the distinctive things about the lens of the eye is its refractive property. Perhaps your cornea should be mostly transparent (98% or more) and should have some refractive index added, as well. I'm not sure how the DAZ eyes are built, so I don't know how this would be implemented, but it should add to the realism of the eye, I think.... - Dex
ren_mem ( ) posted Thu, 26 January 2006 at 7:37 PM
I gotcha. I haven't done too much w/ poser stuff either or studied eyes, however, throwing this together I got what looks like a good place to start anyway.Heres a post. Uses V3 textures.
ren_mem ( ) posted Thu, 26 January 2006 at 7:39 PM
I didn't really set reflection this could be looked at. I didn't use alpha. 100% trans instead. Index of refraction is water. Shininess is 65%.
estherau ( ) posted Thu, 26 January 2006 at 7:44 PM
off to try it - love esther
ren_mem ( ) posted Thu, 26 January 2006 at 7:45 PM · edited Thu, 26 January 2006 at 7:46 PM
If you set to around 20% more or less that works. Don't want it to look like glass.
Message edited on: 01/26/2006 19:46
estherau ( ) posted Thu, 26 January 2006 at 7:55 PM
what do i do with transparency - fresnel etc? love esther
ren_mem ( ) posted Thu, 26 January 2006 at 8:01 PM
Reflection works a bit differently now. You set the shader part to a percentage(around 20%. You could try fresnel, but I don't think it will work well I would leave it a 0)
ren_mem ( ) posted Thu, 26 January 2006 at 8:06 PM
16% looked ok in preview, but didn't render yet.
estherau ( ) posted Thu, 26 January 2006 at 8:16 PM
16% shiny? what % transparency?
ren_mem ( ) posted Thu, 26 January 2006 at 8:27 PM
shiny I have high. 65% Under reflection the is another brach in the tree called shader click on that drop down then select value 1-100%. 16% looks ok. You may find viewing angle etc may change the look.trans is 100%, but no alpha.
estherau ( ) posted Thu, 26 January 2006 at 8:28 PM
I thasn't come out well but I don't k now what I am doing wrong. Love esther
estherau ( ) posted Thu, 26 January 2006 at 8:31 PM
I'm trying again. thanks for clarification. Have I got the refraction bit right? Love esther
no - still not working well.
ren_mem ( ) posted Thu, 26 January 2006 at 8:42 PM
yeah refraction is right. I am a bit confused because it looks like you have all the shaders for you model in there. The parametric map looks like it could be the cornea from the little ball, but you only want to do this to the cornea shader.I brought mine in via daz obj for this and merged groups so mine could be setup differently.If you look I just have multichannel then texture map.Set that shader under reflection to 16% value.
ren_mem ( ) posted Thu, 26 January 2006 at 8:46 PM
Parametric mapping seems to have no effect...didn't think it should, but I just checked.
estherau ( ) posted Thu, 26 January 2006 at 8:51 PM
I'm not sure what you mean.
ren_mem ( ) posted Thu, 26 January 2006 at 8:54 PM
Ignore the other texture issues here, but here is a render.
ren_mem ( ) posted Thu, 26 January 2006 at 8:59 PM
Your textures are different. Ignore the parametric comment. It doesn't matter.I am going out for a bit will be back so don't think I disappeared. I think you will have to tweak. Yours just looks a bit glassy so maybe just turn the shader under reflection down.
estherau ( ) posted Thu, 26 January 2006 at 9:17 PM
Noooo don't leave me aaaghhh - okay, see you soon! love esther ps will try adjust reflection
ren_mem ( ) posted Thu, 26 January 2006 at 10:34 PM
sorry I am back...had to run before store closed.LoL. Didn't want to leave you hangin. How did it go?
ren_mem ( ) posted Thu, 26 January 2006 at 10:38 PM
My textures are free vicky lo res so they aren't so great to begin with especially up close.
ren_mem ( ) posted Thu, 26 January 2006 at 10:53 PM
esther, I think part of the issue is your base texture looks like it may already have a reflection built in.I have seen some with fake reflections also. You may need to examine the underlying textures. Are the eyes just too glassy or what do they look like? I am sure not only do you need good textures, but there is probably tons of technique and theory behind doing eyes. Gotta be some tutorials around.
estherau ( ) posted Fri, 27 January 2006 at 12:37 AM
Yes it has got some reflection drawn onto the texture - ist that what you mean? Love esther
ren_mem ( ) posted Fri, 27 January 2006 at 1:14 AM
Yep. That will make a difference. Something made into the texture can throw things off alot.If you can't replace the fake reflection(which cannot be adjusted and won't look real)then you may need to turn reflection down.It will be hard to tell if this is your problem or something else.You could also try to use only reflection instead of refraction(or try refraction in a 1-100%)Shininess you may want to adjust also. You may turn shininess and refraction down to nothing then add them back that will help you see how each affects the texture.
ren_mem ( ) posted Fri, 27 January 2006 at 1:24 AM
Also, your really strong light in the eyes will effect it also(that may be for demonstration only). Try the fake GI Indoor lighting scene and see if you like that as a starting point.
estherau ( ) posted Fri, 27 January 2006 at 2:09 AM
in the shader with the texture I ticked the little box that said make white invisible. I don't know why I did this, or what it does but the cornea I think is looking better. I'm just going to check it from all angles. Love esther
estherau ( ) posted Fri, 27 January 2006 at 2:15 AM
the pupil isn't dilated properly because of the overlying texture on the cornea otherwise it looks quite good - like i mean really good! love esther
estherau ( ) posted Fri, 27 January 2006 at 4:48 AM
i just took the texture away and changed it to a black colour - first test not too bad, but no reflections so i'm turning them back up and i think i'll have to turn some on for the pupil too. love esther
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 10:46 AM
There is a reasonably priced set of eye textures in the market place that I picked up... great real looking irises and you can chose to use textures without reflections on them. I bought them and they work great for using them in carrara. I'm not trying to do a commercial for someone's product but if you want to know which ones let me know. And I made the mistake of a blonde... when I typed in alpha in my earlier post... I use transparency and a low refraction setting on the cornea. Great progress both of you! Christina
My Art
estherau ( ) posted Fri, 27 January 2006 at 5:14 PM
Hi Christina, Thanks, that sounds interesting too. do you use a texture in the colour part of the cornea and if so, with or without reflections usually? Love esther
Samhain74 ( ) posted Fri, 27 January 2006 at 5:58 PM
estherau ( ) posted Fri, 27 January 2006 at 6:48 PM
Christina, when yous ay low refraction settings, what sort of thing are you talking about. I have tried water set at 1.0 Love esther
ren_mem ( ) posted Fri, 27 January 2006 at 7:38 PM
Well glad it's working esther. The box you checked for transparency is normally checked when you are using the transparency channel like an alpha channel. This depends on how the texture is setup, but is often used. I think christina may be referring to what I mentioned earlier about setting the shader under refraction to a 1-100% value like you did with reflection and starting low and working your way up.You have to show us your render.enigmaticfrog I think posting the link is fine to a product you like...it is certainly relative.
ren_mem ( ) posted Fri, 27 January 2006 at 7:45 PM
Oh I see you did that in the regular channel.
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 7:47 PM
I usually don't use a texture on the cornea... since our corneas are clear... and I use anywhere from 1.0 to 2.0 refraction. The iris textures I like are eye to eye by billy-t I think. I know the package is eye to eye here in the MP. Will pop out a render.... C~
My Art
estherau ( ) posted Fri, 27 January 2006 at 8:47 PM
Hi enigmaticredfrog, i would like to try clear corneas too - could you pleasse tell me the complete settings for the whole cornea? Do u modify a preset like clear plastic? love esther ps this pic is using a texture that a friend sent in the colour channel, and transparency is around 98% Love esther
estherau ( ) posted Fri, 27 January 2006 at 8:48 PM
ps the left pupil is dilated, the right can't dilate because the iris texture is part of the cornea Love esther
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:10 PM
Ok... here's a front view...
My Art
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:10 PM · edited Fri, 27 January 2006 at 9:11 PM
view 2... ignore the pixiated skin text... yuck
Message edited on: 01/27/2006 21:11
My Art
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:12 PM
opps... pixilated.... grrr... fingers didn't work
My Art
this one needs tweaking because you can't really see the cornea... :P
My Art
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:22 PM
ah that's a little better.
My Art
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:25 PM
ok esther... here's what I've got... color: none alpha: none highlight (usually none depends on my mood) same with shininess bump none reflection value 16% refraction value 2% everything else none
My Art
ren_mem ( ) posted Fri, 27 January 2006 at 9:40 PM
Those are good eye textures ef.The skin is good too.esther those look good..she has big eyes. If you have only cornea textures that are just a dome and they are 100% transparency should that create a clear dome?
enigmaticredfrog ( ) posted Fri, 27 January 2006 at 9:43 PM
It should create a clear dome... as I understand it...
My Art
ren_mem ( ) posted Fri, 27 January 2006 at 9:49 PM
I see...yeah that gives you a different look.
ren_mem ( ) posted Fri, 27 January 2006 at 9:58 PM
I would think it would I don't think too many eyes are done like that tho. black as a highlight tends to look about the same as none.
  • 1
  • 2
