Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
...Hmm. I guess that might not make a lick of sense if you're not 45 or older ;) Ya see two or three decades ago there was this commercial where the other kids would watch and see if Mikey survived trying a new food. I gotta remember not to make obscure references to lame old commercials for pete's sake. Sorry ;)
OK...you don't have to be that old to get it. Mikey was around later than that :D Yeah volumetric light issue corrected would have been great. I did see that the transparency GI issue seems solved. YAH! Will have to check some of these other rendering bugs that were fixed.
No need to think outside the box....
Just make it
invisible.
Been using it for a week? I noticed that I'm no longer getting asked for the location of .obj and texture files of poser .pzz imports, but my Aiko bug looks to be too far down the queue / too recently reported to have made this list for this round of patches.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
I noticed that Cognito shows up right under my Distant Light effects setting after installing the 5.03 update. I don't remember seeing it there before.
Mark, I may not be following you here. Up to Carrara 5 I could click and drag the drawing plane to determine where I wanted my object mirrored, this was a vital technique for making Poser clothing and other symmetrical objects. Now this isn't possible. Selecting a vert or an edge to point the drawing plane(s) to has pr oven unsatisfactory since it's aligned to the edge in all three dimensions so a cleanly centered "cut" isn't possible. The manual still describes the click and drag method for moving the drawing planes. IF there is another method for doing this I would be happy to adopt it if someone can point it out to me... PLEASE! As it is now I export form C5 into C4 to do my mirroring, which is a very bulky work flow. thanks mike
Hi Mike, I see what's getting you - the dragging. After determining which drawing plane you want active by using the working box selector on the left, select which vertexes/polys you want, hold the modifier key (Command or Control depending on your system) and ONLY click on the vertexes/polys that you selected. the drawing plane will snap to that selection. At least that's how it works here... Mark
just because someone is on SS doesn't mean they are old... :P and you don't have to be 40+ to know who Mikey is....Mikey likes it. :D Great memories....
Christina -- "Love me but don't tell me so" Lilly
Bart
My Art
Mark, Just recieved a reply back from Eovia that they recognize the bug. THe problem is if you send the drawing plane to a poly/vertex/edge it rotaties to match the selection's X,Y,Z position. Some times whan mirroring you need to set the plane without any rotation and move the vertices to it then make the mirror. That's where the click and drag feature is necessary. mike
Yeah it's a bit bulky. I'd prefer to see them mirror similar to the assembly room. That mirrors everything at exactly the same distance from the center point as the object to be mirrored, as long as you could select which direction to mirror in X, Y, or Z, but, as it stands, the duplicate with symmetry feature in the vertex modeller is almost useless, at least for the type of work I'm doing. mike
Just saw this on Eovia's site and am downloading now. Anyone installed this yet?
