Wed, Nov 13, 7:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Subject: How do I apply a V3 MAT to a Aiko body?
DrMCClark ( ) posted Tue, 28 February 2006 at 8:15 PM · edited Wed, 13 November 2024 at 7:31 AM
I have a MAT (skin texture) from a V3 character I would like to use on an Aiko body (actually an Aiko-SP body). I know the MAT doesn't fit quite right, leaving the legs unchanged. How do I fix this?
infinity10 ( ) posted Tue, 28 February 2006 at 8:34 PM
Just go to the Materials room and manually choose the texture for the part of the A3 legs which haven't yet got the V3 texture.
Eternal Hobbyist
svdl ( ) posted Tue, 28 February 2006 at 10:08 PM
And then save as a material collection (if you have P6). You could also edit the MAT pose file, CR2Builder by kim99 (free) is perfect for the job. Open the .pz2 in CR2Builder, leave the material nodes collapsed, copy the "material SkinLeg" node", paste it, and rename it to "material SkinShin". Repeat for all missing material zones, save the .pz2 as a new file, and you're done.
My gallery   My freestuff
DrMCClark ( ) posted Wed, 01 March 2006 at 6:31 AM
I'll try the pz2 edit, but how do I save as a material collection? (Sorry for the newbie question)
infinity10 ( ) posted Wed, 01 March 2006 at 6:44 AM
Get the pose applied to the figure. Go inside the Materials Room. Make sure the right hand side contents menu drawer is pull open. Click on the Plus Sign. Add whatever name you wish to use for the PZ2 file when the small pop-up window appears. Cheers, and Happy Mat PZ-ing !
Eternal Hobbyist
Whoops - you ARE using Poser 6 ? Those are Poser 6 steps.
Eternal Hobbyist
svdl ( ) posted Wed, 01 March 2006 at 11:19 AM
The pz2 edit method has the advantage that it works in each and every Poser version. Poser 6 Material Collections have the advantage of not cluttering up the Pose library. Alas, Poser 6 only.
DrMCClark ( ) posted Wed, 01 March 2006 at 7:52 PM
Yes, I have P6 ;)
Phantast ( ) posted Thu, 02 March 2006 at 5:36 AM
It only takes a moment to copy and paste the texture to the legs - it's hardly worth cluttering up your library further to prevent you from having to do that again.
FreeBass ( ) posted Sat, 04 March 2006 at 1:42 PM · edited Sat, 04 March 2006 at 1:43 PM
Use UVMapper.
Load Aiko, import Vic's UVs directly from the v3 obj, save Aiko under new filename, hack Aiko Cr2 to point to new filename.
Simple, innit?
Message edited on: 03/04/2006 13:43
WARNING!
This user has been known to swear. A LOT!
Meddlesom ( ) posted Sun, 05 March 2006 at 1:10 AM
I personally just open the V3 MAT file in a text editor, make three copies of SkinTorso (only because that's usually the first one in the list) and rename them to SkinThigh, SkinShin, and SkinKnee. Then I save the MAT file again. The new MAT will still work for victoria 3 but it will also work for all the other unimesh figures too. You don't need to make a seperate MAT for all those characters, in fact in my MAT pose directory I just have them all grouped under one folder called Unimesh.
DrMCClark ( ) posted Sun, 05 March 2006 at 6:34 AM
Good suggestions. I'll be sure to make use of them all as I get better with Poser ;)
