DAZ|Studio F.A.Q (Last Updated: 2024 Sep 22 4:53 pm)
That's a tutorial for DAZ|Studio
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
OOOOOOOOOOh I think got it now.. Thank you so much...the pics helped alot......when I get it right my fist Image will be dedicated to you . :) hmmmmmmmm I was looking at your surface window on the last pic.. mine doesnt have a copy/ Paste button. Can that be the problem also? Im using the new DAZ/Studio 1.2.0.1
If the list is showing, the copy/paste buttons should be too - can you post a screen shot of your surfaces palette? It sounds as if something odd is happening. muller: dod you have cast shadows on for both the light and the props? And do you have a surface for the shadows to be cast onto? And are you doing a 3Delight render - OpenGL shadows can be iffy depending on your hardware.
Message edited on: 02/24/2006 09:12
YFD: click the button with a triangle, level with the word Surfaces and on the right-hand edge of the palette - select Show surface list from the menu that pops up. That will get you a list of surfaces that doesn't go away when you click on an item (making it easier to select multiple surfaces at once) as well as the Copy/Paste buttons for settings. Muller: 3Delight is the software renderer, as opposed to the hardware assisted OpenGL renderer that uses your video card. Got to Render>Render settings and drag the slider at the top all the way to the right (if it isn't already) to use it.
If I wanted to do a kneeling or bending model over a reflective floor, what would the best kind of lights to use and where? I've tried spotlights, but I'm not sure of the best places to put them. this is the result so far, V3 tyra and the vampi suit by BHV, Daz studios slick hair and cyclorama portrait backrops, jens reflective floor and a couple of spotlights, one was over the top of v3, and one for just underneath by V3. Any ideas on getting this to work right? I've followed the reflection idea above for the floor, but I'm stumped with the lights idea.
Hi all, I got a black reflective floor from freebie section, but for the life of me I can figure out how to get the reflection....can some1 please tell me how to do it, or point me to a tutorial. thanks
