Yup, that's the one. I did have a go in hex, but have to be honest. At the moment nothing is quite gelling in my brain. I have never done any 3d modelling, so its not going well.
I have actually managed a reasonable facsimile by using Steve Ray's incredible morphing cube. Rough but it will do at a pinch with a good tex map.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
I can also have a go if you like, although it looks like danamo is doing a good job.
Come visit us at RenderGods.
Ignore the shooty dog thing.
Thanks Mahray. The more the merrier AFAIC,LOL. I'm just trying it 'cause It's an interesting object and Pam needs one. You may well have a better take on this 'cause the stringy part is taxing my ingenuity. I thought about using the spline-modeler in Carrara for that part, but I need more practice with it. I may try to kludge the rest of this together in Wings too.
Hmmm, another thought occured to me. I could just try to UV map the basic low-poly model here and paint a bitmap and displacement map to use on it in Carrara. Carrara5 will let me export the micro-displacement as a high poly model, though Chohole uses a lot of high-poly DAZ figures and probably doesn't need the "extra calories",LOL.
The cube I have modified is over 18000 poly's, without the tensioning strings. I have uvmapped it and added them on a tex map, but the general shape is not right.
This is a poser render..looks better in bryce.
Wow that is looking really good.
Steve Rays incredible cube (free stuff here) is pretty cool, if a bit heavy on polys for a cube, but it does do some great things. I used a combo of 2 of his morphs to get the shape, then exported an obj from poser (Did I mention its a poser prop?) and mapped it cylinder cap in uvmapper, and saved the new obj and the map.
I also use his alternative primitives a lot, like cubes and things with rounded or bevelled edges, they are for Bryce.
Me I just sort of look at the interface of Hex, and think now what do all these things mean. Think its time I went and found a few basic modelling tuts before I boot it up again.
Well, I think I'm finished with this Pam. I'll send you the .obj ZIP, if you like. It has 36,490 polys, 5 material/object groups, and weighs in at 1.55MB in standard ZIP format.
Thanks again Danamo, it's ab fab!
:biggrin:
Thought I had seen one in freestuff somewhere, but can't find it at the moment. does anyone have any ideas please. :huh:The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
