DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Attached Link: http://mysite.verizon.net/sfg0000/
I would recommend the free program Poseray. Its very easy to use, It has no modelling abilities to get in the way, just read a file in and export the OBJ file.Even though it offers superb rendering, I have often used it just for conversion of 3DS and Lightwave files. Sometimes even for 'correcting' OBJ files that didn't come out of D|S quite right.
regards
pk
www.planit3d.com
For Poseray:
Import
Goto the input tab (first on the top left, top row)
Click the Load file button to find the folder and file on your drive
Click Load selected
Export
Go to the OBJ output tab (last on the right, top row)
Choose or change the file name
Click the Save file button, choose a folder and press OK
regards
pk
www.planit3d.com
Quote - Export 1. Go to the OBJ output tab (last on the right, top row)
Are you sure there isn't anything else to do here? I just installed PoseRay last night, been playing about with it for a while, converting .3ds and .lwo models into .obj format with .mtl file. One small problem: the .mtl file is still being ignored when I import into D|S. I know D|S had a problem with this some time ago, but I thought it had been fixed. Or is there something I could be doing wrong in the import?
I've tried re-loading the new .obj into PoseRay, it comes up all right with all textures applied.
Can anyone please tell me if these files are compatible with DAZ and how to install them. Thank you.![😄](https://cdn.jsdelivr.net/emojione/assets/4.5/png/32/1f604.png)
