Sat, Jan 25, 4:10 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: .3ds - HELP PLEASE!!! ^^
Eela ( ) posted Mon, 12 June 2006 at 7:48 AM · edited Sat, 11 January 2025 at 6:03 AM
Can anyone please tell me if these files are compatible with DAZ and how to install them. Thank you. 😄
RHaseltine ( ) posted Mon, 12 June 2006 at 8:04 AM
Not directly - you need to use a free modeller or converter (or a non-free one if you like) to convert them to OBJ files, which DAZ|Studio can read. Look at www.wings3d.com and www.blender3d.com
Eela ( ) posted Mon, 12 June 2006 at 8:55 AM
thank you ^^
Prikshatk ( ) posted Tue, 13 June 2006 at 4:06 AM · edited Tue, 13 June 2006 at 4:10 AM
Attached Link: http://mysite.verizon.net/sfg0000/
I would recommend the free program Poseray. Its very easy to use, It has no modelling abilities to get in the way, just read a file in and export the OBJ file.
Even though it offers superb rendering, I have often used it just for conversion of 3DS and Lightwave files. Sometimes even for 'correcting' OBJ files that didn't come out of D|S quite right.
regards
pk
www.planit3d.com
Eela ( ) posted Tue, 13 June 2006 at 6:12 AM
Thanks ^^
Eela ( ) posted Tue, 13 June 2006 at 6:56 AM
um, ok downloaded both programs and still don't get it or the manuals Embarassed um can i have some help please? 😊
Prikshatk ( ) posted Tue, 13 June 2006 at 8:05 AM · edited Tue, 13 June 2006 at 8:09 AM
For Poseray:
Import
  1. Goto the input tab (first on the top left, top row)
  2. Click the Load file button to find the folder and file on your drive
  3. Click Load selected
Export
  1. Go to the OBJ output tab (last on the right, top row)
  2. Choose or change the file name
  3. Click the Save file button, choose a folder and press OK
regards
pk
www.planit3d.com
leehilliard ( ) posted Wed, 21 June 2006 at 4:15 PM
i'm glad istumbled in here. your help is greatly appreciated, i accidently dled some 3ds. now i can actually use them.
Prikshatk ( ) posted Thu, 22 June 2006 at 4:01 AM
Quote - ... i accidently dled ...
I thought (just for a second) you had accidentally died :scared:
:biggrin::biggrin::biggrin:
regards
pk
www.planit3d.com
leehilliard ( ) posted Fri, 23 June 2006 at 12:15 AM
not died ,downloaded . your help is greatly appreciated thanks.
Star4mation ( ) posted Fri, 30 June 2006 at 1:10 PM
Thanks for the tip on Poseray  pk. Just downloaded it, works a dream :) now I can convert my extensive .3ds collection to use in D/S too!!
Steve:)
If it ain't free, I can't afford it.
SpottedKitty ( ) posted Sun, 02 July 2006 at 6:01 PM
Quote - Export 1. Go to the OBJ output tab (last on the right, top row)
  1. Choose or change the file name
  2. Click the Save file button, choose a folder and press OK
Are you sure there isn't anything else to do here? I just installed PoseRay last night, been playing about with it for a while, converting .3ds and .lwo models into .obj format with .mtl file. One small problem: the .mtl file is still being ignored when I import into D|S. I know D|S had a problem with this some time ago, but I thought it had been fixed. Or is there something I could be doing wrong in the import?
I've tried re-loading the new .obj into PoseRay, it comes up all right with all textures applied.
Eela ( ) posted Mon, 03 July 2006 at 2:23 AM
wow cool , thanx ^^
prixat ( ) posted Mon, 03 July 2006 at 7:19 PM
You're right spottedkitty. I hadn't noticed.
A way round that is to edit the mtl file in notepad. I changed the relative paths for each kd_map statement to the full path and put it in quotes.
eg
becomes
map_Kd "c:mapsVADERBUT.JPG"
regards
prixat
