Thu, Feb 6, 1:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 11:58 am)
Subject: I've learned my lesson about using freebie poses
infinity10 ( ) posted Wed, 04 October 2006 at 7:59 PM · edited Thu, 06 February 2025 at 1:00 PM
From now on, I'm going to stick with commercial pose packages.  And get them from stores which do quality testing.
I laboured to get my M3 character's injected morph settings just right, then applied a freebie pose from somewhere.  Bang !  The morphs settings revert to dial value zero, and are frozen.  Nevermind, can't delete or reset those injected morphs either.  Dang it !!!!
Thank goodness I made a backup of my custom character.  Sure, I could work around it by posing the figure first, then adding the props and hair and injecting the morphs, but it is very difficult to adjust everything in place correctly in a posed figure.
Eternal Hobbyist
Acadia ( ) posted Wed, 04 October 2006 at 8:10 PM
I use lots of free poses and don't seem to have troubles. I just tweak as needed.
The order I do things:
Load figure
INJ character
Add hair
Add clothing
Maybe change hair
Maybe change clothing again (hey, I'm a girl!!!!!!!!!)
Pose
Add props
Tweak pose
Add lights
Check it all
Render
JenX ( ) posted Wed, 04 October 2006 at 8:14 PM
I'd recommend emailing or IM'ing the creator of the pose pack.  Maybe they're new at it, or maybe they accidentally included a REM pose to the pose file.  Let them know what's going on, and they may even fix it! ;)
Jeni
wheatpenny ( ) posted Wed, 04 October 2006 at 8:18 PM
Site Admin Online Now!
In my experience, most freestuff is perfectly safe to use. Depending on who made it, a lot of it has the same quality control as commercial stuff.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
nruddock ( ) posted Wed, 04 October 2006 at 8:32 PM
Quote - ... or maybe they accidentally included a REM pose to the pose file.
Probably saved the pose with morph channels included but all at 0.
Easy to fix if there's no tricks being used in the file (seems unlikely) :-
Apply pose to figure, resave to library.
dphoadley ( ) posted Wed, 04 October 2006 at 9:10 PM
Use the poses first on the Poser Mannequin, and then resave them.  This will clean them up from any undesired detritus.
David P. Hoadley
infinity10 ( ) posted Wed, 04 October 2006 at 9:31 PM
Ah, David, that is a most interesting approach to take.  Noted, will try that.
All - many thanks for your replies.  All noted as well.
Eternal Hobbyist
linkdink ( ) posted Wed, 04 October 2006 at 10:25 PM
David - yes, this is a heck of an idea! I have some old poses I created and saved when I started that have junk like morphs and translated hips.
But they are good poses so I would love to clean them up with a trick like this. Thanks!
This reminds of what I do to documents sometimes to get rid of junk -- save as a .txt, then resave as a Microsoft word .doc.
Gallery
Angelouscuitry ( ) posted Wed, 04 October 2006 at 10:38 PM
I do'nt think you need to use the mannequin.
To get rid of the morphs, just resave the pose and click "No" when Poser asks you if you want to "Include Morph Channels," after you've named the pose, and clicked OK.
And to get rid of the Hip translation just make sure the Hip is'nt selected, and resave.
dphoadley ( ) posted Wed, 04 October 2006 at 11:22 PM · edited Wed, 04 October 2006 at 11:29 PM
The Stick figures and Mannequin were originally created so as to create poses that wouldn't affect the 'Body Sculpting' morphs.  Angleoucuitry's suggestion would probably work too, but to be safe I believe it's best to pose a figure that has absolutely NO morph channels whatsoever.
BTW, this suggestion isn't originally mine, but one I picked up from reading the old forum archieves -those that date back to 1999.
There is a lot of information stored in those old archieves, the developement of Eve by Torino, the controversy over the first Vicky (more than a few thought that she was 'Butt Ugly', a sentiment to be echoed later over Judy), and various other situations.  In short, it pays to dig and delve.
Yours truly,
David P. hoadley
PS: One of the benefits of MY suggestion, is that you won't have to redo any dial twirling on your own custom created figure after applying a pose.  After having worked all day on a customised figure, save it FIRST as a Pz3, thin load the mennequin and apply pose, resave pose, and then apply to Pz3 figure.  This way, if you've made a mistake, you can reimport your work without any significant loss.
As in any customised work: SAVE, RESAVE, & SAVE AGAIN!!!!
BastBlack ( ) posted Thu, 05 October 2006 at 12:43 AM · edited Thu, 05 October 2006 at 12:45 AM
I've had poses do that, or make the hair jump, and other wacky things. Four solutions: 1) Use the animation bar. I keep my character with my settings at zero, then apply poses to frame 10 or so. If there is a morph problem, just select all the morphs on frame ten and click delete. That will keep the pose, and reset morphs to frame zero's settings. 2) Morph lock. I believe Poser Tool Box has a morph lock. (And if you ask me, Poser 7 should come with a morph lock feature too). 3) Save often. Save your pz3, and save character to the figure library too. 4) Undo. This has saved me so many times. It will reset unless you did something right after the pose changed your morph settings. bB
infinity10 ( ) posted Thu, 05 October 2006 at 1:57 AM
Wow absolutely great tips.  I ought to have thought of using the animation frames trick !  Clever.
Eternal Hobbyist
amacord ( ) posted Thu, 05 October 2006 at 3:50 AM
well, heres my suggestion: read the files in your text-editor before you install them. and take a look at the file-size before you do that. a simple posing file with more than 50 - 60 kb will most likely make trouble. a (V3)morphing pz2 with some 200 kb includes the zeroed morph-channels and will inevitably erase all your previous settings. install nothing before you know what it really is. sure, its boring, but its save.... A.
Phantast ( ) posted Thu, 05 October 2006 at 5:24 AM
Good ideas here!
pakled ( ) posted Thu, 05 October 2006 at 7:08 AM
If I use a pose at all, it's usually only a starting point to do something else..;) Some poses have a way of moving fingers into strange positions, but they can be fixed. Injections I don't know about..;)
Darboshanski ( ) posted Thu, 05 October 2006 at 7:25 AM
To be honest I've had some freebie poses I liked a whole lot more than some of the commerical ones I've bought.
My Facebook Page
Realmling ( ) posted Thu, 05 October 2006 at 8:38 AM
My trick to save my custom characters (this is usually from myself...I'm a disaster waiting to happen) once I get everything set the way I want, I tell poser to spawn a morph target for everything and then I only have one dial to set for my character.
This way, if a pose messes things up, I can easily reset those dials that shouldn't have anything and I'm good to go.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
infinity10 ( ) posted Thu, 05 October 2006 at 8:48 AM
That's another good idea, thanks Realmling.
Eternal Hobbyist
Peelo ( ) posted Thu, 05 October 2006 at 9:21 AM
You can allso delete all the morphs with morphmanager from the pose file. Fast and easy.
-Morbo will now introduce the candidates - Puny Human Number One, Puny Human Number Two, and Morbo's good friend Richard Nixon.
-Life can be hilariously cruel
amacord ( ) posted Thu, 05 October 2006 at 10:33 AM
funny, now we talk about it..... i just ran into a posing pz2 from danies pose boutique. this file sets a pose as it should, but after actor lToe it starts again from actor rThigh and zeroes the morph channels of both legs... really weird!:blink: you see, even good merchants make their small mistakes, and IMO danies poses are the only ones worth their money.
arcady ( ) posted Thu, 05 October 2006 at 11:44 AM
Quote - the controversy over the first Vicky (more than a few thought that she was 'Butt Ugly', a sentiment to be echoed later over Judy)
This problem has remained throughout the vicky line.
The value of vicky is in her morphability, not her default looks.
There are some facial types that work well in real life, but not so in 3D. in 3D, V1-3 look like drag queens.
I never thought of trying the mannequen, I would have just loaded the 'blank' version of the figure, posed that and overwritten the original pose (but kept by first backing up the png graphic of it if I had liked that).
pz2 files tend to be small, so I have also just manually edited them before in a text editor. In fact, funny as this may sound, despite being in the Poser community since 1999 this is how I always made my own partial poses until last weekend when I realized I could just select parts of the figure and save that as a pose... :) Even after all these years, the obvious can still be missed...
  • My latest gallery image was help by my realizing this obvious aspect to making partial poses, as the figure in the foreground is using a comination of two poses from my past efforts and some new partials made for that scene.
Looking at the ideas so far, I might look to using a blank figure, saving the pose without morph dials, and then applying it to my morphed figure. I'd resort to the mannequin after that if only to avoid going through a different figure. Not that my results would likely be any different, but that would just feel more comfortable for my preffered workflow.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
BastBlack ( ) posted Thu, 05 October 2006 at 3:40 PM
"You can allso delete all the morphs with morphmanager from the pose file. Fast and easy."
MorphManager can read a pz2?
bB <- who also does spawned morph targets :)
MatrixWorkz ( ) posted Thu, 05 October 2006 at 6:45 PM
Sure it can, just rename it to a cr2, delete the morph data, rename back to Pz2 and save.
My Freebies
nruddock ( ) posted Thu, 05 October 2006 at 7:30 PM
Quote - Use the poses first on the Poser Mannequin, and then resave them.  This will clean them up from any undesired detritus.
You need to apply the poses to the figure that they're intended for otherwise you'll lose values for any bones that the target figure has, but the Mannequin doesn't (e.g. buttocks, collars, hands and fingers), when you resave them.
MatrixWorkz ( ) posted Thu, 05 October 2006 at 8:58 PM
That too is true, but most of the DAZ figure I have come with a BLANK version that can be used instead for just such an occasion. It's one of the things CP did right when they released the new G2 figures as well. Apply the poses to these figures first and then resave them to their own Pose library with no morph data and you have just what you need.
My Freebies
