You can "render" Cartoon-with-lines by making a one frame animation, if you want something that is larger than your workspace. Or just anitalias that and save the picture.
Cartoon-with-lines aren't renders per se, and they should not be confused with the sketch Designer in Poser. Cartoon-With-Lines is a good way of getting an idea of where the shadows fall on a Sketch render though :o)
Is there a tutorial / thread on the Sketch Designer? Also can you change the Render default style?
I really like the Cartoon with Lines style, but the default is to render to full Texture shaded. Can I change this? I can get a Cartoon w/Lines figure image into Paint Shop Pro but the props or backgrounds are poorly shown. My ideal would be to compose a scene in Texture Shaded so I could check it then render it in Cartoon w/Lines. Is this possible? Is there another way?
