Wed, Jan 8, 12:39 PM CST
Subject: Sketch Designer/different renders
Colin_S ( ) posted Wed, 04 October 2006 at 6:53 AM · edited Wed, 08 January 2025 at 12:16 PM
Is there a tutorial / thread on the Sketch Designer? Also can you change the Render default style?
I really like the Cartoon with Lines style, but the default is to render to full Texture shaded. Can I change this? I can get a Cartoon w/Lines figure image into Paint Shop Pro but the props or backgrounds are poorly shown. My ideal would be to compose a scene in Texture Shaded so I could check it then render it in Cartoon w/Lines. Is this possible? Is there another way?
raven ( ) posted Sat, 07 October 2006 at 2:48 PM
This one may help with the sketch designer.
http://www.drgeep.com/TUT/sd/sd.htm
Colin_S ( ) posted Tue, 10 October 2006 at 3:20 AM
Got it, many thanks.
Even off a quick look before work, picked up 1 point I hadn't thought of, that lighting affects the sketch design and render as it does the full one
TrekkieGrrrl ( ) posted Tue, 10 October 2006 at 5:23 AM
You can "render" Cartoon-with-lines by making a one frame animation, if you want something that is larger than your workspace. Or just anitalias that and save the picture.
Cartoon-with-lines aren't renders per se, and they should not be confused with the sketch Designer in Poser. Cartoon-With-Lines is a good way of getting an idea of where the shadows fall on a Sketch render though :o)
