Mon, Nov 25, 3:36 AM CST
Subject: First Bryce6 Freebie: 24 HDR-ready materials
madmax_br5 ( ) posted Sat, 21 October 2006 at 2:45 AM · edited Mon, 18 November 2024 at 9:33 PM
Well here goes! Here are 24 simple "base" materials that are designed for use in HDR scenes. Many are designed to be used with blurry relfections enabled for best results, although it's not absolutely neccessary: Download HDR materials for Bryce 6 matrenderlayout.jpg If you try them out, please post the image here so I can see how ya'll are working with them. Thanks, and enjoy! -Max
tom271 ( ) posted Sat, 21 October 2006 at 3:39 AM
How do you use these "mat"   I was using hdr files?  please explain...
How to best install also...  what catagory are you placing your mats in...?
Thanks
Tom
Mahray ( ) posted Sat, 21 October 2006 at 7:20 AM
Tom - to install just extract the .mat file into ..Bryce 6PresetsMaterialsUser
Not sure where to put this one, but since I'm using a couple of Max's mats, I thought I'd dump it in here.  The primitives are real, the rest is HDRI image.  For this to work you'd probably need to use a larger resolution for the hdri.
Come visit us at RenderGods.
Ignore the shooty dog thing.
pakled ( ) posted Sat, 21 October 2006 at 10:37 AM
uh..do they work (in any capacity) in Bryce 5?..;)
striving ( ) posted Sat, 21 October 2006 at 3:29 PM
Not getting how to use these. I added em in to materials. But when I go to the Skylab, it is only looking for HRD files???
How do ya use these?
tom271 ( ) posted Sat, 21 October 2006 at 3:48 PM
I have not tried this but MAYBE you set your model with reflection and put this mat, on a surface,  near but out of camera sight and let your model reflet the mat....  sounds like the only way to do it....
Tom
madmax_br5 ( ) posted Sat, 21 October 2006 at 5:32 PM
Sorry guys, biut of a misunderstanding. These are not HDR files, but materials to be placed on objects within a scene that is lit with .HDR files. You apply them to regular objects in your scene, and load a separate .hdr of your choice in the sky lab.
tom271 ( ) posted Sat, 21 October 2006 at 5:43 PM
Thanks for clear the bit of misunderstanding...
jfike ( ) posted Sat, 21 October 2006 at 7:49 PM
Well, I thought I would do a little test.  I downloaded the HDR scene provided by AgentSmith entitled  "HDRI & Render Speeds - Example & Download."  Then I duplicated the "thingy" object a couple times and applied three of the textures provided by madmax_br5 (this thread..)
This render with HDR turned off and took 40 seconds on my little laptop.
jfike ( ) posted Sat, 21 October 2006 at 7:51 PM
... and here it is with HDR on (35 minute render.)
Mahray ( ) posted Sat, 21 October 2006 at 11:55 PM
Well worth the extra 34 and a third minutes, in my opinion :)
tom271 ( ) posted Sun, 22 October 2006 at 12:15 AM
Great render.. I like the look to the objects....  a little caustics on the glass....
