Forum Moderators: RedPhantom
It's an idea. I wouldn't have tought they'd have much time fo it but I'll give it a go. A part from some specific question (like why does my joint centre keep resetting a zero, and why don't the entries I make into the centre joint x y z boxes make any difference)much of what I need to know is just typical newbie stuff so I'm still offering the Hawaii. Thanks for the tip.
I use the joint editor all the time, and have no idea how it actually works! Sometimes it seems dragging the center is the same as typing in the boxes, other time it doesn't seem to work that way. There is some kind of relation to the centers and the actual part in the object file too, but it is really, really hard to figure out what exactly is going on.
When I drag the centers, It updates the Center values in the joint editor window, but then everything goes back to zero if I dare to touch something else (for example the fall off zones). Typing in the boxes does sweet FA! they just reset to zero as soon as I change the focus to something else. I keep thinking I've got some kind of bug, but then I've thought that so many times nd usually it's just because I'm not following the rigid preocedures Metacreations thought up, and then didn't bother to include pop warning messages for when you abuse them.
No Sirs! I'm using Win98 and have the same problem! I have installed a German Version and the update 4.03. It's strange! But we are now three or for 'foreigns' with the same poser-problem. May be a special Poser 1th.of May virus? I also introduce this problem to CL, meanwhile I'm editing the *.cr2. This helps! Greetings Daniel
It's so silly!!!!! we know where the mistake is coming from: We, as European are using a comma instead of dot for writing a decimal value! Now it's clear, why you never got this mistake! F.e. just type -0.043 instead of -0,043 In our case it's working now! We are going to send this message to all the other fellows in the 'outlands' Greetings Matthias PS: We'll get the $50???
Hy bloodsong, sorry for being misunderstood! I mean typing the value in Poser -> joint parameters -> center. So I can insert the value in these inputfields (by using a '.' instead of ',') and after insertng the values it doesen't change to zero. So, there is no need to edit the *.cr2 (which needs a little bit experience in doing this...) Greetings Matthias
Wo, I went off on a 'I'm never gonna get this kimono to fit depression' when I turn around, there's answer coming from all directions. Thanks for the suggestions, I'll try them, but I'm a bit sceptical because I usually edit the values in the wondow around the decimal place leaving it untouched - I've seen the problem you describe Kruse in the morph dials - that's where I developed the "don't touch that dot" technique - but I'll try in the joint editoer. Then I'm off to learn how to editr Cr2 - just for the fun! angola
Not a get rich scheme, but I'm ready to beg someone to take my fifty if they're prepared to dedicate an hour to answering my questions about why the flaming joint editor keeps giving me such hard time. I can find my way around so I'm looking for a quick DO's & DON'Ts with Q&A. I thought it could be done by chat. I'm France based so payment might be a bit difficult to organize. I could always buy a few identical sets of models if your on the marketplace...
