Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 12:26 am)
I have similar rendering issues! :0/
Just getting it do do a simple test render it struggles compared to P6 :0(
This is before you think about Exporting.
I posted fuller details on another recent thread.
Klutz :0(
Life is a beta.
In faecorum semper, solum profundum variat.
What I do is save the finished render in a JPG format with 0 compression and I also save it with 100 compression and both pics look like crap. The renders are 58 KB in size and that is so small. In Poser 6 I render the same scene and its like close to 300 KB and looks a million times better. It's like Poser 4 with bad textures.
Adrian
Here is what i posted in another thread...It may have got buried ;0)
' It seems to be awfully slow at a simple test render. I am really beginner level at this TBH.
I am talking minimalist stuff here, one figure and no props. One that I could do in P6 in about 30seconds seems to bog down and even freeze it.
I have backed off the auto Firefly render to draft quality, but it still seems awfully slow!
Must have some things checked as default that P6 doesn't I suppose?
Anybody else got an issue like this?
( For the record 2 Gig Athlon64 2 Gig memory and 128M GeForce Graphics. ) '
Klutz :0/
Life is a beta.
( For the record 2 Gig Athlon64 2 Gig memory and 128M GeForce Graphics. ) 'Klutz :0/
Nige, try to find the latest driver for your graphics card --it makes a huge difference.
So far rendering works fine with me --and fast!... :)
Panos
"That's another fine mess you got me in to!" -- Oliver Hardy
Quote - > Quote -
Klutz :0/
So far rendering works fine with me --and fast!... :)Panos
I'll do that now, Panos....
Good idea..Thanks for the prompt!
Nige. :0)
Life is a beta.
Tried that....Graphics driver updated...Seems quicker graphics generally...
Hasn't solved the problem though...
One Sidney plus hair hit render on Firefly auto and it choks then freezes! :0(
Life is a beta.
Can we see a sample just to compare - it's not an issue i have.
Show me yours and I'll show you mine - so to speak....
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
The difference well may be the system requirements of Poser 7 as opposed to 6. Compare system requirements, does P7 ask for more? It seems each new generation of software requires higher and higher computer resources. How much ram do you have? Perhaps it's time to add some more. Another thing that might help is to turn off all programs operating the in background.
P7 might ask for more, but it will very likely run very smoothly on LESS - just memory, I consistently had P6 go to 2gb and croak, while P7 has been pretty well behaved, at least outside of the cloth room (another story). I told Preferences to let the render run in a separate process and that is working well for me, you might try that and see if you get different results.
I don't know if you HAVE to do anything, but I was setting up and saw under General Preferences -> Render that the threads Firefly thinks it can spawn is set to 1 by default, so I changed it to 4 (max). I hadn't actually tried it with default, I'll do that though and see if it works the way it reads. Generally 1 thread = 1 core.
OK.
Tastiger: I have no render to show you :0(
Randy: Not getting as far as Exporting an image.
Teyon: I am just using 'out of the box' P7 Firefly settings.
Tomsde: I suppose it could be an issue, but th system is fairly well specced
see resume below.
2.00 Gig AMD64:
2 Gig RAM:
128Meg 6800GT Graphics ( updated driver today ;0) )
SAMS3D: Don't know TBH
PJZ99 : Never been an issue with Poser 6 ...Things running in the background and still churning out the basic test render I am referring to in about 30 seconds....P7 chokes and freezes.
Wonder if it could be Sydney or her hair, that is the only other difference ??? :0/
Thanks folks for the input so far!
Klutz :0)
Life is a beta.
It may be the hair slowing you down though to be honest, your system sounds pretty decent (though you may want a beefier display card). Did you set Poser to use more processes than just one? This may be slowing things down if you didn't. I myself am on a P4 with 2Gigs of Ram and a 512MB ATI card. I have Photoshop, Poser7, Windows Media Player, Outlook Express, Firefox and IE running. My renders or a single character with hair usually takes a bit less than three or four minutes depending on the hair and textures. That's at the highest setting.
You should fire off an email to tech support, as there may be something else slowing things down that you're not aware of.
OK
Found it..
Bucket size it says 64
Shadowcasting and Raytracing are off.
Displacement 0
I'm trying it like this and see what will happen.
Life is a beta.
PUT NUDITY WARNINGS IN YOUR POSTS! Is it that hard? Some of us browse the forums at work and rely on these things to avoid NSFW threads. :-p
(Marked for nudity to tag the thread properly)
¤~ RadiantCG ~¤~ My Renderosity Gallery ~¤
Sorry about the nudity thing....
Didn't twig it was the first naughty posting...even without nipples LOL
Mind on about five diverse things at the moment TBH! :0/
Thanks for the input, folks.
Right.....On the face of it then, I just have the issue of the auto settings then, I suppose?
Klutz :0/
Life is a beta.
Thanks for your help and patience ;0)
I'll do that, Teyon.
Uh Oh!
Links to support from the program aren't working either....Still links to curious-labs.
Tried substituting e-frontier...Not having much luck with that URL either.
Probably still the big download issue....
Ah well, I'll try another time.
Klutz :0)
Life is a beta.
It looks like the site's having some issues at the moment, as I can't access them right now. It's probably a bit of overload with Poser's new launch. I'll speak with Uli tomorrow though, so he'll hear about your problem. He may not have an easy solution without you being able to provide your info so keep trying the TechSupport links.
J-peg settings in Poser have always been tricky, even a slight increase in output quality can create nasty looking, pixellated images. If you're planning on doing an post work on your images it's best to save as PSD (for photoshop users and Elements) or TIFF. Yes they take more memory, but they won't degrade on you.
You could also try a P4 engine render, depending on the look your after that might be good enough for some things.
Thanks for every ones help with this problem. It seems that Poser 7 is going backwards in regards of saving a quality image. I've always saved my work in a JPG format in Poser 6 with high quality and it looks great. With Poser 7, the quality is horrible. It seems I have to jump through hoops to make a normal JPG file that Poser 6 could do with no problems. With Poser 7 it doesn't even come close to the quality of Poser 6 out of the box. Is there some kind of setting that I'm missing? TIA.
Adrian
Yes most people save in a PSD format but what I'm trying to say is, why does Poser 6 allow you to save a really nice JPG but Poser 7 doesn't? Poser 6 has always done that for me even though I shouldn't save my renders in a JPG format to begin with, but at least it gives me that option. Poser 7 doesn't have that capability yet.
Adrian
I hope they fix this. For stills, yes, you can save as a TIFF or some such thing. But what about animation? I usually render as a series of still images, so if Poser crashes, I can continue where I left off. I usually use a quality of 70-80, and adjust the filesize in my animation app. Rendering to TIFF would take a lot longer, then I'd have to convert to JPG, since my animation program doesn't do TIFF.
I know with mine and I use 2 monitors - it pops up a "quality" selection box after you hit the save as jpg button - you can then select from 0% - 100% - However, mine comes up on monitor 2 so I'm not sure where it will pop up on a single screen.
it alive.
Robert A. Heinlein
Windows 11 Pro
Hi all,
I found exactly the same bug in Poser 7 here, ie do a quick test render and try to save as a jpg.
First, they have changed the dialog box so you get to choose the quality in a separate box now, and they don't bother telling you which is the good and bad end (not that I need telling but all the same... :) )
Also, no matter what setting you choose, all jpgs are indeed coming out at low quality. A TIFF looks fine though.
What I did then was to go back to Poser 6 just to make sure I was not just getting something wrong. I opened the last scene I had done in 6, and before I actualy did a render, I clicked on the render tab, and there was my Poser 7 pic!
I did the render, made sure I was right about being able to change quality, and then when I dragged the slider over, my new P7 pic was still there in the render stack!
How, I have no idea, I accepted default folders for everything, I have versions 5, 6 and 7 on this machine, and 5 & 6 never interacted at all.
Anyway, this was late last night, so I gave up trying to figure it out and I am pleased to see this thread to bounce it around.
I don't know if its me or not but Poser 7 renders look horrible. They look fussy and they are only 60 KB in size and when rendering the same scene into Poser 6 its like 280 KB and a very good picture. Is there a setting I need to tweak? I don't get it. Also, I can't load my Runtime folder into Poser 7 from Poser 6. Any help would be greatly appreciated. So far I'm not impressed.
Adrian
