Tue, Jan 21, 3:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Material Room Help
Anniebel ( ) posted Tue, 19 December 2006 at 12:55 AM · edited Tue, 07 January 2025 at 12:44 AM
Ok an item I want to texture doesn't have a texture map but has material zones
Can you tile a texture to cover the zone? If so how?
Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
pjz99 ( ) posted Tue, 19 December 2006 at 1:32 AM
I think what you want is - on Advanced view in Materials Room - to create a node on Diffuse_Color -> New Node -> 2d Textures -> Image Map, which leaves you with a node you can set Image_Source for and browse for a file.  You have options to UV scale, offset and tile as you like from there.  Does that help?
My Freebies
pjz99 ( ) posted Tue, 19 December 2006 at 1:38 AM
e.g. I put that on a box primitive prop.
My Freebies
Anniebel ( ) posted Tue, 19 December 2006 at 1:45 AM
Thanks, yes I know how to add a texture map as you descibe.
The item I want to texture isn't UVmapped, so there is no texture map.
What I want to do is tile a texure - you know like you do in PSP with a small tile to fill a bigger area.
Thanks anyway.
Helen Keller
pjz99 ( ) posted Tue, 19 December 2006 at 2:00 AM · edited Tue, 19 December 2006 at 2:05 AM
Well, that's what I thought you meant - primitive props aren't UVmapped either are they?
edit: never mind I see what you mean (texture goes on each face of the item, which is no good)
My Freebies
Acadia ( ) posted Tue, 19 December 2006 at 7:11 AM
You do the same thing as above, only browse to your tile.  Then you can adjust the size of the tiling using the U and V Scaling.
Also, I tend to connect the image map node to the Specular Colour and change it to black unless I want it shiney in which case I leave it white.
Anniebel ( ) posted Tue, 19 December 2006 at 10:36 AM
Ok I see, I have never used the scale thingy.
Thanks
Helen Keller
