Thu, Feb 20, 8:16 AM CST
Forum Moderators: RedPhantom
Subject: Tutorial - HDR Shop with any background image
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:46 PM · edited Mon, 17 February 2025 at 11:33 PM
Attached Link: http://www.physicalc-software.com/tutorials/ibl/
I've gotten some interest in how I create my images.  My technique is derived from a tutorial by face_off.
First, in HDR Shop load the image that you want to create you image-based lighting from.  Go to File --> Open and select your image.  A pop up will appear, just click "OK".
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:47 PM
Now, our light must come from different directions.  So go to Image --> Panarama --> Panaramic Transformations
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:49 PM
A pop up will appear... you can experiment with different options.  I typically use either Angular Map or Longitude/Latitude.
Your image will appear warped...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:53 PM
Then go to plugins --> lightgen plugin.  BTW, your lightgen plugin should be installed in a folder titled "plugins" in the same location you have HDR Shop installed.
This pop up will appear...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:55 PM
Click the browse button to set a name and location for your light file.  Reset the number of lights from 20 to about 5.  Lastly, click the button for "scale light output."
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:57 PM
Click the "Execute" button.  During the calculation, an error message may appear.  Just click "OK."
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 5:58 PM
Now in photoshop, open the same background image.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:00 PM
Now crop out the area of the image you may want to use as your background in poser.  Then go to image --> image size and change the dimensions so that it will fit in your preview window in poser.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:04 PM
In order to provide, depth of field, the background image must be blurred.  If blurring doesn't take place, if you render at a larger render size, your background may appear pixelated.  Go to filter --> blur --> gaussian blur and adjust the blur to your desire...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:05 PM
Save your image with a new file name.  Then in poser go to file --> import --> background image...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:06 PM
The preview image will resize to the dimensions of your background.  Now it's time to import our lighting.  Go to file --> run python script
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:08 PM
Browse to the location of where you have saved the ImportLightsfromHDRShop python.  Select and click open...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:10 PM
You will then see a pop up labelled "tk" and then another pop up prompting you to open your light file.  Browse to the location where you saved your lights using HDR Shop...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:11 PM
Then you will see another pop up asking what percentage to assign to the IBL light... You can experiment, although the recommended 30 is usually best...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:12 PM
Then a texture manager pop up will appear, select the original image that you based your lighting off of and click open.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:13 PM
The background will be assigned to the IBL light, click OK...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:14 PM
Then a pop up will appear demonstrating that the script is completed.  Just click the close button.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:15 PM
In poser, set your rendering settings...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:17 PM
Then do a practice render.  In this case, our lighting is a little severe.  Because we are using normal images rather than HDR images, there is a bit of trouble shooting that may need to be performed.  This can include shifting the positions of some of the lights or changing the colors slightly.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:18 PM
In this case, I will make the color of each lighter slightly paler.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:19 PM
Then re-render...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:20 PM
Now use whatever props you may desire in order to make your figure look less pasted on a background...
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:23 PM
Render to your desire image size.  Then in photoshop, we are going to intensify the saturation of the colors.  In the actions tab, select either "oil paint" or "soft poserize."  Change the layer setting to "soft light" and adjust the opacity to your desired effect.  Then select your background and create a duplicate layer.  Go to filter --> stylize --> find edges.  Move this layer to the top and set the layer setting to "soft light" and decrease the layer opacity to 10%.
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:24 PM · edited Fri, 09 March 2007 at 6:25 PM
Go to Layer --> flatten image.  Here is the end result...
JHoagland ( ) posted Fri, 09 March 2007 at 6:25 PM
Very nice tutorial. It reminds me a lot of Eric Van Dyke (Traveler)'s Poor Mans HDRI tutorial. But, your images use a later version of Poser. ;)
VanishingPoint... Advanced 3D Modeling Solutions
PapaBlueMarlin ( ) posted Fri, 09 March 2007 at 6:32 PM
Attached Link: http://www.renderosity.com/mod/gallery/browse.php?user_id=27965
I haven't seen that tutorial before, but yes it's basically the same principles.  This tutorial was made using Poser 6, but it works for Poser 7 as well.  I haven't tested it in Poser 5.
For examples on how HDR Shop images might appear, you can check out my gallery here to decide whether it is something you desire to implement into your renders.
Hope this tutorial is helpful...
RAMWorks ( ) posted Fri, 09 March 2007 at 9:57 PM
Nice tutorial there PBM!! 😄
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
Indoda ( ) posted Sat, 10 March 2007 at 6:48 AM
Great tutorial - should it go into the tutorial section of the site makes it easier to find later? Thank you for sharing all this information.
The important thing is not to stop questioning.
- Albert Einstein
Indoda
MariaM05 ( ) posted Sat, 10 March 2007 at 11:04 AM · edited Sat, 10 March 2007 at 11:07 AM
Hey, i followed your tutorial, and heres what I did... how is it..
dphoadley ( ) posted Sat, 10 March 2007 at 12:04 PM
PapaBlueMarlin ( ) posted Sat, 10 March 2007 at 12:06 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1217007&member
Try to reimport  your background.  When it tells you that it will change the dimensions of the preview window, click OK.  The background you selected has no natural light.  It's still okay, but it means that you will have to change the color of some of the lights and possibly reposition a few.
It's what I did for the image in the link - so it can still look natural.
PapaBlueMarlin ( ) posted Sat, 10 March 2007 at 12:13 PM
Attached Link: http://gl.ict.usc.edu/HDRShop/
HDR Shop is a program from which you can create light files that can be imported into poser.
PapaBlueMarlin ( ) posted Sat, 10 March 2007 at 12:19 PM
Maria, this should be the screen pop up you see when you first select to import your background.  click the yes button.
MariaM05 ( ) posted Sat, 10 March 2007 at 12:46 PM
Ok, so then i did two more... to see if i knew what u was talking about...
MariaM05 ( ) posted Sat, 10 March 2007 at 12:48 PM
then another...
dphoadley ( ) posted Sat, 10 March 2007 at 12:53 PM
Would this method also work on background images pasted to primitimes, such as flattened cubes or curved surfaces?  With a bsckground image pasted to a primitive, I can use displacement and bump values to enhance the 3d effect.
DPH
PapaBlueMarlin ( ) posted Sat, 10 March 2007 at 1:17 PM
Maria: It looks to me that your light change was done in photoshop rather than poser.  You will have to change some of the colors of your lights.  Specifically all of the green ones to make them more pale.
DP:
It could be done that way, but remember your background image is blurred to provide depth of field.  Plus, too many curves could cause the lights strange angles on your background.  But feel free to experiment and see if it works for you.
MariaM05 ( ) posted Sat, 10 March 2007 at 1:36 PM
How about now? Almost?
MariaM05 ( ) posted Sat, 10 March 2007 at 2:19 PM
ok im done, im loving my outcomes!
PapaBlueMarlin ( ) posted Sat, 10 March 2007 at 5:31 PM
Much better!  I think you're getting the hang of it :)
