DAZ|Studio F.A.Q (Last Updated: 2025 Feb 04 6:17 am)
Shaders do require files that get installed to folders in the root folder of the D|S installation - eg StudioShaders - so if you deleted that folder, or installed to a different folder and just linked or moved your Content folder, those may well be missing which would potentially cause such problems (there's a definition file, as I recall, which tells D|S which parameter controls are needed).
Hello, all.
Just installed DS 1.5 after running 1.4.16 successfully for some time. It appears that, when I load the AH light source for IBL lighting, although it is successfully added to my Scene tab, nothing appears for it under the Parameters tab.
Any suggestions are welcome... thanks...
-Whirlwind
