Sun, Jan 26, 9:46 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: D|S 1.5 problem with Pendragon's shaders?
whirlwind ( ) posted Fri, 27 April 2007 at 2:56 PM · edited Sat, 25 January 2025 at 11:08 PM
Hello, all.
Just installed DS 1.5 after running 1.4.16 successfully for some time. It appears that, when I load the AH light source for IBL lighting, although it is successfully added to my Scene tab, nothing appears for it under the Parameters tab.
Any suggestions are welcome... thanks...
-Whirlwind
prixat ( ) posted Sat, 28 April 2007 at 1:53 AM
I'm not having any problems with the shaders in the new version. Are the AH hair and AH skin shaders working OK, it may be an installation issue?
regards
prixat
RHaseltine ( ) posted Sat, 28 April 2007 at 8:51 AM
Shaders do require files that get installed to folders in the root folder of the D|S installation - eg StudioShaders - so if you deleted that folder, or installed to a different folder and just linked or moved your Content folder, those may well be missing which would potentially cause such problems (there's a definition file, as I recall, which tells D|S which parameter controls are needed).
