Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 4:06 am)
Not sure which one of the duplicates to reply to lol.
Learning poser is trial and error IMO. You can read the manual but unless your ability to retain TONS of information is unsurpassed - it wont matter. Just decide something you want to do and do it. When you hit a road block ask about it. Learn as you go.
V2-3-4 are models for use in poser. They are sold at www.daz3d.com.
You can find many characters for use with those models in the marketplace here. You can get Apollo - a male model for free (Im sorry I don't have the site link for that but you can find about 2000 banners for it in peoples signatures if you look around.)
My advice:
Start small
Learn the file system/structure for poser
Dont give up!
I am: aka Velocity3d
ratscloset would be the one to know about products over at CP. I was going to suggest VTC.com, they also have a Poser Video. Poser 5 Demystified is yet another video, that would take you through all of the Rooms.
If you click on my Avatar's homepage link, you will see a male and a female character. The male is Daz3D's Millenium Man Michael 2(M2 for Short.) I think he is the best male figure for Poser. For a good look at him click on the Lips in my Signature. Daz3D does also have David 3, whom is a nice second. Just do'nt confuse M2 with M3, they are totally different. Recently, RuntimeDNA, has introduced an Ultimate Body Morph Set, for the Poser 7(P7) default figures.
The Female I use is Daz3D's Millenium Woman Victoria 3.0(V3.) V3 is Poser's best female figure! People will be foaming at the mouth to point out that Daz3D Millenium Woman Victoria 4.0 has recently been released, but they are two totally different figures all together. The distinct advantage V3 has over V4 is several years of Artists' Communities' development(Magnets, Morphs, Textures, Hair, Etc.,) where V4 was just released 2 or 3 months ago. Untill a week or so ago, V4 also did'nt have any of the Muscular morphs Daz3D is quite famous for(With M2, D3, and V3.) So, V4's Musclular Morphs have finally been released, but I hav'nt tried nor seen anything compareable to V3 yet.
The following information will be helpful to you. Further down is a list of newbie tutorial links.
A picture to show you the file structure of a Poser Runtime can be found here:
http://www.daz3d.com/support/faq/index.php?id=94
Unfortunately the above link no longer works. Daz seems to have removed it. I have contacted them and have requested that they put it back, but I haven't heard back from them as yet.
Basically, what it boils down to in a nutshell:
If you are looking for a Character or a piece of clothing/shoes, in Poser you will find them in libraries/character
If you are looking for hair, you will find them in either library/character/hair OR library/hair
If you are looking for character texture addons, hair textures, clothing textures, you will find them in library/poses. Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2
If you are looking for props, they are located in library/props
Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop.
Figure items are "conformed" or "parented"
Props are parented.
If you are just starting, it's best to get started on the right foot. DO NOT just install files into the runtime! That will only lead to frustration because you won't be able to find anything, and not all files are packaged equally and land up all over the place.
Here is a link to a tutorial on using multiple runtimes.
http://forum.daz3d.com/viewtopic.php?t=9060&start=0
Another tip is to never just unzip or install anything directly to your runtime. Always unzip or install to a separate folder. Then browse through the folder to have a look at the structure of where things are going and make sure that it's in "proper runtime structure" so that when you move it to the runtime, they get into the proper folders.
Once you get your files installed, the next thing you want to do is to start making things :)
Here are some great newbie tutorials that will get you through the bare basics:
http://trekkiegrrrl.dk/tut1.htm
http://www.poserguide.nimprodaction.com/issues/issue2/cover.htm
http://www.poserguide.nimprodaction.com/issues/issue3/cover.htm
http://www.canary3d.com/tutorial/3d-intro.htm
http://www.ebonshire.net/tut-posb/index.php
http://www.cooltuna.com/poser/poser-tutorials.html
Dr. Geep Studios ( Basic to Advanced Tutorials. Periodically offers free classes for Poser)
If you don't have the Daz V3 or the V4 figure, you should pick one or both. I'd personally suggest that you go with the V3 one as it's been around for years and there is a TON of freebies around for her, as well as a TON of stuff in the various Poser stores. It will be a couple of years before V4 catches up with clothing content and stuff and V3 stuff won't work on V4 because they are different figures. There are work arounds to getting clothing from a figure to fit another figure. I've included information on that further down. which is a popular figure, you should get it.
3D Models Pack (incl V3) Free from Daz at Download.com
But if you want to change the look of her face and body, or use any of the available character addon packages, you need to buy the head and body morphs.
The V3 head and body morphs are here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3008
Also, Michael 3, is available free right now too at Daz3D. Again, like Vicky, you need the head and body morphs to change the shape of his head and body. Those can be found here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3009
If you have both figures, you can get both of their head and body morphs in one package, here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3010
NOTE: You can use the textures from the character addon packages without having the head/body morphs.
If you want to change the look of the head/body and have the head/body morphs, do the following:
Install the head and body morphs.
Locate the morphs you want to use in the "Poses" folder.
Find the set of morphs you want to inject IE: Full Body, Full Head.... or just certain parts.
Left click the picture
Click the Single Checkmark at the bottom of the page.
Go to your Parameter Dials and start turning dials. (make sure that you have the part of the body you want to adjust as the active one IE: Morphing the ears, make sure you have the had selected.
Also, you can find many, many free morphs and textures for Vicky, and Aiko, and some even for David and Michael. So you don't have to turn any dials if you don't want to. Here are a couple links to get you started.
http://www.renderosity.com/mod/freestuff/index.php?user_id=55140
http://www.renderosity.com/mod/freestuff/index.php?user_id=178490
http://www.renderosity.com/mod/freestuff/index.php?user_id=105158
Using ready made character addons is pretty easy. You need to have the figure and it's head and body morph packages installed.
Load up the figure IE: Vicky
Go to the Poses folder, and instead of looking for your morphs from the packages, look for th character you want to use. Left click the image that has INJ, click the SINGLE checkmark at the bottom and the morphs for that character's look is injected into your figure. No dial turning necessary. Of course if you want to tweak the settings you can, but that's not mandatory.
Next locate the textures (if the package has some). They will be usually in the same library menu as your INJ that you used. Left click the image for the texture and use the SINGLE checkmark to apply it. If you don't like that texture, apply another one overtop.
You can even use a texture from another package. IE: Morphs from package A and textures from package C. Or morphs from packag A, texture from package C, eyes from package D, lips from package E. the combinations are endless :) If the packages have their head morphs seprate from the body ones, you can mix and match morphs too. IE: body morphs from package A with head morph from package D. That allows for even more versatility.
There are lots of sites out there that has free V3 character addons, and some that have for Aiko, Michael and even David.
Hair, clothing and textures are all figure/item specific, which means:
Michael 3.0 needs hair and clothing and textures made for Michael 3.0
Victoria 4.0 needs hair and clothing and textures made for Victoria 4.0
Victoria 3.0 needs hair and clothing and textures made for Victoria 3.0
Victoria 2.0 needs hair and clothing and textures made for Victoria 2.0
Aiko needs hair and clothing and textures made for her.
Like figures, a texture made for one hair style can only be used on that hair style.
Clothing is also specific when it comes to textures. A texture for a pair of pants, won't fit all pants... just the pants that it was made to fit. Same with all clothing items.
Sometimes you can manage to clothing item to fit another figure by tweaking of dials and increasing or decreasing the scale percent, but that doesn't always work. Sometimes a clothing item for Victoria 2 will fit Victoria 3, but their joints are different so posing a figure wearing clothing not made for it specifically will be hard.
Some figures can share items more easily than others, here is a link that will help sort that out:
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2682279
There are 3 types of clothing:
Dynamic: This is clothing that you use inside the Cloth room. It takes longer to work with and there is a bit of a learning curve, but it's not too bad, but the results are more appealing in that the clothing actually looks more natural instead of "posed and stiff".
Confroming- Non Morphing: This is clothing that you conform to a figure. The clothing is made to fit the base figure. If you change the shape of the figure you will also have to refit the clothing, which isn't always easy if there aren't any corresponding body morphs in the clothing. Plus posing a character in positions where they are not nearly upright is difficult. But many prefer this type of clothing over dynamic.
Conforming-Morphing: This is the same as conforming-non morphing, only there are morph dials that you can turn that have corresponding body morphs for easier fitting. This is the preferred type of conforming clothing because it's easier to fit.
There are programs that can help fit clothing from one figure to another, or even from the same figure to one that has been "morphed up" using their morph packages.
The Tailor, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=677
Wardrobe Wizard (I use this one and it's great). It can be purchased from PhilC's site here:
http://www.philc.net/WardrobeWizard.htm
Clothes Converter, which can be bought here:
http://www.daz3d.com/shop.php?op=itemdetails&item=3069&cat=131
Things like hair can be used across all figures just by tweaking the scaling and trans dials and then parenting the hair to the figure.
Poses are something else that can be used across most human-like figures with just a bit of tweaking to dig out a hand, or fix a shoulder.
These are all things I learned along the way and found to be valuable, so I try to pass them along because I know how frustrated I was when I first got Poser. Hopefully you will find the information helpful.
say." - Ghandi
I should have mentioned the Millenium Figures Base is not the only required purchase. You also need to purchase Daz3D's own Morphs pack of each Figure. The figures are basically useles without them.
The best place to get started with DAZ is at Download .com. DO search for DAZ, and you find free downloads to the Bases of Victoria 3.0, Michael 3.0, Aiko 3.0, and Hiro 3.0, in the Poser/DAZ Studio 3D Models Pack 1. You'll also find Bryce 5, and it's Presets, there!
**Acadia: That is a great comprehensive list. The FREE Apollo Max figure can be downloaded at: http://www.antonkisieldesigns.com/~akfiles/htmlpages/ApolloMaximusFree3dhumanfigure.htm
This figure is just too good to pass up and very versatile. I've had better luck with it in creating new characters than I ever had with any of DAZ's figures with all the morphs. Worth the download! Nothing to lose since it's free. Maybe one day soon Apollo will find a wife.**
Poser 2, 3, 4, 5, 6, 7, 8, 9, 10, Pro 2014, 11, 11 Pro
Thanks to everybody for the help. I'm going thru every suggested link. Your art work , so perfect, so real, scares me. How long will it take to get there ??? I've been using photoshop since version 2.5, Illustrator and they seem simple to Poser 6. Hope I'm wrong, because lately I'm spending hours with this software and sometimes I feel like giving up. John
Attached Link: V3, M3, Aiko and Hiro for free
Hey, following this link you will find V3 base, M3 base, Aiko base and Hiro base for free. So don't buy these characters, go towards their morphs (head and body morphs) and save your money so ;)Aiko and Hiro are manga style characters, but are versatile enough to get a realistic style. With little tricking, you can share texture maps between Aiko and V3, and Hiro and M3 (although V3 and M3 can share theirs too).
" How long will it take to get there ??? I've been using photoshop since version 2.5, Illustrator and they seem simple to Poser 6. Hope I'm wrong, because lately I'm spending hours with this software and sometimes I feel like giving up. John""
John,
I've spent a few hours at least every day for about 6 months now. You've seen my progress, so there ya go. It does seem like an incredibly slow process - but as I've said, as long as you learn something every time you open the program (even if it is what NOT to do) you are making progress.
If you have used photoshop for that long, you probably know it better than I do - now that IS a complicated program with about a billion variables - if you can learn that well, you have this in the bag.
Don't give up. I firmly believe that the truly good things in life test us, by MAKING us want to give up. For me, Art has been one of those. The frustration just makes every accomplishment that much sweeter.
I've started using Poser with Poser 3, and then more an more with each version. I got into the DAZ Millenium Figures(M2 and V3) right when Poser 5 came out. That was when I started looking at Poser ike an Instrament. SInce then I've worked on Poser, about all day, every day.
I think the secret is to really make a conscious effort to do Character Studies for specific Figures. Much work that goes into one figure does'nt work with any other figure, so you really need to research where you'll want to spend your engery. I'd have prefered only one figure, but have needed to to have a helthy Male and Female.
Some will dissagree, but I think spreading yourself too thin and over too many Figures, is a huge waste of time. You do'nt get around to everything that's really needed to make one figure shine, the first time around Poser, and then it's all chance from there.
