Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
All you need to do is change the extension to .jpg in Windows Explorer and then open the pp2 files in a text editor and do a search/replace for .bum and change them to .jpg.
I know it's a lot of work but that's the easiest way. I had to do this when I moved over to P5 and I'm now on P7 so I'm happy I did this a while ago.
Hugz from Phoenix, USA
Victoria
Yes, I've had situations where Poser is looking for .bum files too or a .jpg image with "bump" in it, but there aren't any such files with the package. As Victoria_Lee said the best way is to use a graphic program and just resave your images as a .jpg files. Then open the .pp2 file and using the "find" feature found either under "file" or "edit", and look for .bum. Replace it with .jpg. And then resave the .pp2 file.
.bum files are for poser 4 and aren't using in Poser 5, 6 or 7.
say." - Ghandi
I have that set and just did a quick peek at a .cr2 file and a .pp2 file and didn't find any calls to a .bum file. Of course, I deleted the P4 version a while ago so that may be your issue. The package comes with both P4 and ProPack versions and the PP version only uses .jpg files. My suggestion would be, if you're not using P4, just go into the Character, Pose and Props folders using Windows Explorer and delete the GreekBath P4 folders. It won't affect the package at all and you won't get the call to a .bum file.
Victoria
The Installer file size on mine is 25.1 Mb and this is what I get when I load and render the Temple Complete figure.
Victoria
Victoria_Lee, do you have the texture expansion pack as well? That may explain the other versions you have. I have only the Bath Base, Bath complete and Temple Complete files in my install as well. However, when I load the complete items the whole lot loads for me.
WildHunt1, have a look in the geometries->Marforno->GreekBath folder to see if you have the following .obj files:
Base, Bath, BenchE, BenchN, BenchS, BenchW, ColumnsE, ColumnsN, ColumnsS, ColumnsW, Floor, GargoyleFull, GridsDecorations, Ground, Pedestal, SurroundingWall, Templetto, TemplettoBase, Vase and WaterObject.
Also, 2 .pz3 files are included which also load the complete scenes, try loading them, they are located in Runtime->DM Production Pz3's->Greek Bath folder.
If you don't have all of those, I would suggest redownloading the GreekBath from DAZ in case you had a corrupted download before.
Just a guess, but it's probably a case of Poser loading an OBJ file with the same name as one of the ones from this set.
Base, Floor, and/or Ground are the most likely suspects.
To check, import all the OBJ files rather than loading the prop sets.
To fix, you can rename the files in this set, and edit the references to them in the prop and PZ3 files.
In Poser 7, in Geometries->props folder there is ground.obj and in the GreekBath set there is Ground.obj in the Geometries->Marforno->GreekBath folder. It may cause a problem.
Bath Base in the figures library is the filling to your big empty area, which calls for Base.obj (which you could import directly from the geometries folder), which might be the problem, as there is a base.obj in the Poser 4,5, and 7 Geometries->deform folder (Poser 6 has base.obz), which I think is for the magnets base. Try renaming the GreekBath Base.obj and adjust the reference in the Greek Bath .cr2 files and see if it loads then.
