Sun, Feb 9, 4:28 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 06 11:16 pm)
Subject: INJectors... How to use?
Naaman ( ) posted Tue, 03 July 2007 at 12:46 PM · edited Mon, 03 February 2025 at 4:14 PM
So, I've looked through the readme file for this product and I've looked at the Daz instruction manual, but I can't find any info on how to acutally use the muscle morph injectors that I bought yestersay.
When I open the folder (within the Daz program) and assigne the injectors to a figure, no visible change occurs, and no additional options appear on the paramiters menu (no dials or anything).
How do I acutally get them to work, or to have an effect on the character?
Here's a link to the product.  Maybe there's something in there that will explain that I don't have the knowledge to interpret.
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3940&cat=13
Help appreciated.
Incognitas ( ) posted Tue, 03 July 2007 at 1:34 PM
You do HAVE the Victoria 4.1 Morphs I hope?They are the product besides Vicky 4.1 that you need.
RHaseltine ( ) posted Tue, 03 July 2007 at 1:59 PM
Actually, you need Morphs++ only for the full body morphs (Amazon and so on) which are pseudo morphs made up of sub-morphs from the Muscle and ++ sets.
The Muscle Morphs appear as a separate group, under the other morph groups for Victoria 4.1 (not Victoria 4 plain). If they aren't appearing make sure that you aren't using the Rem poses, that you installed to the same folder as for the base figure (and Morphs++ if you have it) and that you ran the updater utility (or for Windows allowed the installer to run it),
Naaman ( ) posted Tue, 03 July 2007 at 1:59 PM
Yes, I have Morphs++ for V4.1
Naaman ( ) posted Tue, 03 July 2007 at 2:05 PM
Hmmm... I'm not sure I understand.  Other morph gourps?  Other than what?  And Rem poses...? I have some "muscle" poses that came with it, but they are just poses.  They don't change the musculature ofthe figure.  In the INJectors folder, there is a "+" injectors and a "-" injectors icon that apparently adds or removes the injectors from the figure, but again, selecting either of these has no effect that I can find.
GKDantas ( ) posted Tue, 03 July 2007 at 3:15 PM
If you have Vic 4.1 you need to run a script ta add these new morphs to the Vic 4.1 installation... when you install Vic 4.1 its ask to create a shortcut at your desktop called "Update Victoria 4.1"
All time that you buy a new morph group for Vic 4.1 its suposed that it runs this script at the end of the installation...
Follow me at euQfiz Digital
Naaman ( ) posted Tue, 03 July 2007 at 3:54 PM
Right, and then a window opens up in DOS and you see it run the script and then, presto!  Everything should work.  I ran the script.  But I can't figure out how to make the Injectors do anything (or, rather, I don't see any way to manipulate them in Daz, where should I look for the dials etc?).
GKDantas ( ) posted Tue, 03 July 2007 at 9:04 PM
I dont have this morphs yet... some morphs has right place to be founded, but these I really dont now where...
RHaseltine ( ) posted Wed, 04 July 2007 at 8:41 AM
When you look at the body of V4 you should see closed morph groups in the Parameter palette - this is what you should see with just V4.1 loaded
and this is waht you should see after injecting the morphs
Naaman ( ) posted Wed, 04 July 2007 at 1:59 PM
Trying it now... I don't remember seeing any Muscle Morphs options... but I'm going to load up the program and see what I get.
Thank you, this is EXACTLY what I was trying to find out.
Loading Daz*
And I'm back.... Nope.  No Muscle Morphs.  There is an icon on the left that shows a very beefy victoria with a + sign in the corner of the icon, there is also an icon next to that one that has the same picutre in black and white with a "-" in the corner.
Is there a step that I'm missing?  I load a figure, I go to Content > Poses > DAZ's Victoria 4 > Morph Injections.  Then I click on the icon.  I get a little loading window in the center of the screen, and then it disappears without changing anything....
I'm going to try re-installing.
Naaman ( ) posted Wed, 04 July 2007 at 2:08 PM
Woohoo!!! Fixed it!!!  I re-ran the 4.1 update, and then reloaded the program and injected the muscle morphs.  It works now.
Thanks for the help everyone.
