DAZ|Studio F.A.Q (Last Updated: 2025 Feb 03 2:53 am)
Actually, you need Morphs++ only for the full body morphs (Amazon and so on) which are pseudo morphs made up of sub-morphs from the Muscle and ++ sets.
The Muscle Morphs appear as a separate group, under the other morph groups for Victoria 4.1 (not Victoria 4 plain). If they aren't appearing make sure that you aren't using the Rem poses, that you installed to the same folder as for the base figure (and Morphs++ if you have it) and that you ran the updater utility (or for Windows allowed the installer to run it),
Hmmm... I'm not sure I understand. Other morph gourps? Other than what? And Rem poses...? I have some "muscle" poses that came with it, but they are just poses. They don't change the musculature ofthe figure. In the INJectors folder, there is a "+" injectors and a "-" injectors icon that apparently adds or removes the injectors from the figure, but again, selecting either of these has no effect that I can find.
If you have Vic 4.1 you need to run a script ta add these new morphs to the Vic 4.1 installation... when you install Vic 4.1 its ask to create a shortcut at your desktop called "Update Victoria 4.1"
All time that you buy a new morph group for Vic 4.1 its suposed that it runs this script at the end of the installation...
Follow me at euQfiz Digital
I dont have this morphs yet... some morphs has right place to be founded, but these I really dont now where...
Trying it now... I don't remember seeing any Muscle Morphs options... but I'm going to load up the program and see what I get.
Thank you, this is EXACTLY what I was trying to find out.
Loading Daz*
And I'm back.... Nope. No Muscle Morphs. There is an icon on the left that shows a very beefy victoria with a + sign in the corner of the icon, there is also an icon next to that one that has the same picutre in black and white with a "-" in the corner.
Is there a step that I'm missing? I load a figure, I go to Content > Poses > DAZ's Victoria 4 > Morph Injections. Then I click on the icon. I get a little loading window in the center of the screen, and then it disappears without changing anything....
I'm going to try re-installing.
So, I've looked through the readme file for this product and I've looked at the Daz instruction manual, but I can't find any info on how to acutally use the muscle morph injectors that I bought yestersay.
When I open the folder (within the Daz program) and assigne the injectors to a figure, no visible change occurs, and no additional options appear on the paramiters menu (no dials or anything).
How do I acutally get them to work, or to have an effect on the character?
Here's a link to the product. Maybe there's something in there that will explain that I don't have the knowledge to interpret.
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3940&cat=13
Help appreciated.
