Forum Moderators: wheatpenny, RedPhantom, Deenamic Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Oct 01 6:00 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
One good tip for all sharp-edged props: prior to importing into Poser, load the OBJ file into UVMapper (preferably UVMapper Pro, which offers greater control) and split the vertices. That gives the whole mesh a "cleaner" appearance, and avoids those dark patches which can be seen on the barrier counterweight, for example. It looks good. I hesitate to potentially add to your work load, but is it a static prop, or have you made it posable?
Attached Link: http://www.actionmanhq.co.uk
Very Nice. I'd certainly use it. It's almost identical to the Action Man Colditz escape setTo see that try link above -> Equipment Manuals ->1974 ->Page 20.
EnglishBob: Thanks for the tip, I will give the split verts idea a try. The way it's set up at the moment is the two sentry boxes are seperate props. The boom is parented to the the pivot post so that it can be raised or lowered and the sign is parented to the boom. The support post is parented to the pivot so moving the pivot will move everything together. Is there a way of limiting the movement of the boom? mrsparky: I checked out the link and it does indeed look like the above, although I used stills taken from the film Battle of Britain for reference. Would like to do an Allied type as well but have been unable to get any clear references with regard to WWII. Didn't realise Action Man had a fan base !!! Thanks for the feedback.
Quote - One good tip for all sharp-edged props: prior to importing into Poser, load the OBJ file into UVMapper (preferably UVMapper Pro, which offers greater control) and split the vertices. That gives the whole mesh a "cleaner" appearance, and avoids those dark patches which can be seen on the barrier counterweight, for example. It looks good. I hesitate to potentially add to your work load, but is it a static prop, or have you made it posable?
English you appear to know something about uv mapper. Can I ask you a couple of questions about mapping an .obj in uvmapper pro?
Don't ask me, since I may not know the answer. Start a new thread and ask the whole forum; that's what we're here for, after all... ;)
