Tue, Nov 19, 10:12 AM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 17 8:21 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Is this good enough......
Touchwood ( ) posted Thu, 12 July 2007 at 6:29 AM · edited Mon, 04 November 2024 at 10:32 AM
Well after an inordinate amount of time trying to get to grips not only with modeling, UV mapping and texturing (all within Blender, not for the feignt hearted either), I have eventually managed to complete something successfully. I originally decided to do this because I couldn't find the right props I needed for an animation so jumped in with both feet. Anyhow, As this is my first attemt, I'm quite pleased it came out OK but would like some feedback on any possible improvements that could be made, or indeed if there's something wrong with them with a view of putting it up as a freebie. I was thinking of maybe dirtying up the Sentry Boxes around their bases or indeed in general as they look a little plastic at the moment. Any comments gratefully received.
grylin ( ) posted Thu, 12 July 2007 at 6:47 AM
very good:D i like what i see:D
EnglishBob ( ) posted Thu, 12 July 2007 at 9:41 AM
One good tip for all sharp-edged props: prior to importing into Poser, load the OBJ file into UVMapper (preferably UVMapper Pro, which offers greater control) and split the vertices. That gives the whole mesh a "cleaner" appearance, and avoids those dark patches which can be seen on the barrier counterweight, for example. It looks good. I hesitate to potentially add to your work load, but is it a static prop, or have you made it posable?
mrsparky ( ) posted Thu, 12 July 2007 at 2:04 PM
Attached Link: http://www.actionmanhq.co.uk
Very Nice. I'd certainly use it. It's almost identical to the Action Man Colditz escape set
To see that try link above -> Equipment Manuals ->1974 ->Page 20.
Touchwood ( ) posted Fri, 13 July 2007 at 12:24 AM
EnglishBob: Thanks for the tip, I will give the split verts idea a try. The way it's set up at the moment is the two sentry boxes are seperate props. The boom is parented to the the pivot post so that it can be raised or lowered and the sign is parented to the boom. The support post is parented to the pivot so moving the pivot will move everything together. Is there a way of limiting the movement of the boom? mrsparky: I checked out the link and it does indeed look like the above, although I used stills taken from the film Battle of Britain for reference. Would like to do an Allied type as well but have been unable to get any clear references with regard to WWII. Didn't realise Action Man had a fan base !!! Thanks for the feedback.
Helgard ( ) posted Fri, 13 July 2007 at 2:30 AM
Touchwood, there is no way I know of to limit the movement in a prop. You would have to make a figure out of it to have that function available.
Your specialist military, sci-fi, historical and real world site.
Lord_syphex ( ) posted Mon, 16 July 2007 at 6:56 PM
Quote - One good tip for all sharp-edged props: prior to importing into Poser, load the OBJ file into UVMapper (preferably UVMapper Pro, which offers greater control) and split the vertices. That gives the whole mesh a "cleaner" appearance, and avoids those dark patches which can be seen on the barrier counterweight, for example. It looks good. I hesitate to potentially add to your work load, but is it a static prop, or have you made it posable?
  English you appear to know something about uv mapper. Can I ask you a couple of questions about mapping an .obj in uvmapper pro?
EnglishBob ( ) posted Tue, 17 July 2007 at 4:36 AM
Don't ask me, since I may not know the answer. Start a new thread and ask the whole forum; that's what we're here for, after all... ;)
