Sun, Jan 12, 12:20 PM CST
Subject: Making waves
decadence ( ) posted Wed, 15 August 2007 at 9:31 AM · edited Sun, 12 January 2025 at 12:08 PM
Could anybody recommend a tutorial or point out how to create waves rolling on a beach? I'm using Vue 6 and there is a texture for foaming water but no matter what I do I can't seem to rotate the waves (texture) in the direction of the beach. Right now the waves run parallel to the beach instead of perpendicular. The waves don't have to be crashing waves, just need some foam/white water where the water meets the beach.
Thanks in advance!
BAR-CODE ( ) posted Wed, 15 August 2007 at 9:34 AM
Mmmm I too do like to know ..but like to ad that i wish to know how to do it without any tool/plugin that cost me money 😉
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
dburdick ( ) posted Wed, 15 August 2007 at 11:43 AM
Here's a tutorial on how to create something like this:
http://www.skinvue.net/Tutorials/BeachShore.htm
BAR-CODE ( ) posted Wed, 15 August 2007 at 12:42 PM
Thnx for the link looks good ..
Anybody knows some good way to make the wave terains ?
Its so strange all kind of styles for making dune's moon craters etc etc .. but no sea wave's ..
Chris
Chris
My Free Stuff
decadence ( ) posted Wed, 15 August 2007 at 12:50 PM
Perfect! Thanks so much. I'll give it a try.
Barcode you could make a wave terrain simply by using photoshop or other making blurry vertical or horizontal rows. Create using black and white or shades of gray and save. Use that pic and import it into your terrain editor in vue....
BAR-CODE ( ) posted Wed, 15 August 2007 at 12:54 PM
That way of doing it i knew "teragen" allready ... i was wondering if someone knew a way of doing it in vue..
Chris
Chris
My Free Stuff
Monsoon ( ) posted Wed, 15 August 2007 at 2:03 PM
Same way in Vue....or any app that uses heighfield terrain modeling.  Make your grayscale wave pattern. In Vue terrain editor, click 'reset' on the left, then 'picture' down below that and import your image. You can fiddle on your own from there. If there are artifacts, press 'diffuse' erosion a couple of times...
dburdick ( ) posted Thu, 16 August 2007 at 12:59 AM
By the way, if you're looking for some great terrains/maps for waves you should check out Monsoon's SeaVue product at 3DCommune.  I use it all the time.
Monsoon ( ) posted Thu, 16 August 2007 at 4:17 AM
LOL...and with SkinVue you can actually go for a dip and get all glisteny and silky wet...it's a perfect match!!
FrankT ( ) posted Thu, 16 August 2007 at 5:35 AM
Ooo now there's an idea for a render . . .  :)
My Freebies
Buy stuff on RedBubble
decadence ( ) posted Thu, 16 August 2007 at 12:18 PM
Quote - That way of doing it i knew "teragen" allready ... i was wondering if someone knew a way of doing it in vue..
Chris
Ummm I was talking about doing it in VUE
BAR-CODE ( ) posted Thu, 16 August 2007 at 12:24 PM
What i meant was just like the way we can make terrain now with dune's, moon, etc etc
I wish they made a water waves option ..like we can make gritt and stones now..
So doing it in Vue with no need to make anything in a other program...
Chris
In teragen "old version" i did use a lot of image to make terrains ....
Chris
My Free Stuff
Monsoon ( ) posted Thu, 16 August 2007 at 1:23 PM
You can.....(depending on what version of Vue you have).  Vue 6 Infinite allows you to take an image and use it as a brush on the terrains . However, you still have to make that image in an outside app.  You could even just reset the terrain, set the rock hardness up to snuff and use the raise painting tool to make your ripples or waves or whatever...
BAR-CODE ( ) posted Thu, 16 August 2007 at 1:28 PM
Now THATS a good TIP !!
It realy is and works fine, i just tryed it ....
And playing with all the tools makes it random every time again
you see this is a such a tip for millons 😉
THNX !
Chris
Chris
My Free Stuff
megalodon ( ) posted Thu, 16 August 2007 at 11:46 PM
Quote - Here's a tutorial on how to create something like this:
Excellent tutorial and beautiful image!
Thanks!
arrow1 ( ) posted Sat, 18 August 2007 at 5:48 PM
Many thanks for a great tutorial.Is there any advice available on animating the water rolling onto the beach back and forth? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
forester ( ) posted Sun, 19 August 2007 at 5:35 PM
Attached Link: Wave Effects by Matt Hausman
For anyone interested in how difficult it is to make waves, the rolling combers, even among the professional CG folks, I commend this article to you. Despite this being posted on the Surf's Up cartooney web site, this is a very professional, and concise description of the technical strategies and processes that had to be employed to create a realistic simulation of rolling comber waves. You might want to make note of the length of time, the number of tools and the number of people involved in creating this kind of thing. WARNING! This article is not for the faint-of-heart! But this should be read by everyone: it helps provide some perspective on the difficulty of this kind of enterprise.
arrow1 ( ) posted Sun, 19 August 2007 at 5:57 PM
Many thanks.I see what you mean that the making waves tutorials is not for th faint-of- heart.I wonder if Vue 6 Infinity could handle this option? Cheers
Mazedog ( ) posted Sun, 19 August 2007 at 7:06 PM
Wow, I was just trying to figure out how to make waves in water earlier today.  I was looking through the Vue tutorials on this site, and there are some there that I’ve been trying to work through. But the one linked by dburdick above is great, because it leverages Vue 6’s new capabilities.
If you don’t have Vue 6 yet, I would take the excellent advice offered here in the forums, and look at the tutorials that are here as well.
forester ( ) posted Sun, 19 August 2007 at 7:36 PM
I'll be trying to create a mesh for a rolling comber, much like the basic one they created in this movie. But, it will take me awhile. It will static, at first, of course.
BAR-CODE ( ) posted Mon, 20 August 2007 at 7:25 AM
Mmmm being non English ...what the banana's is a :Roling comder ????
Chris
Chris
My Free Stuff
forester ( ) posted Mon, 20 August 2007 at 10:12 AM · edited Mon, 20 August 2007 at 10:13 AM
This is a "rolling comber." "Rolling" for the shape of the wave as it rolls over onto the water below. A "comber" is an old American word for a wave that is extra long (linear length perpendicular to the beach). Some very flat beaches with shallow shelving into the ocean produce such waves. Surfers also call these "pipes", and we like them because they make dramatic pictures.
Peggy_Walters ( ) posted Mon, 20 August 2007 at 11:24 AM
Hi forester - I'm keeping my fingers crossed that you will make some waves.  That would be great!
LVS - Where Learning is Fun!
chippwalters ( ) posted Mon, 20 August 2007 at 3:16 PM
Quote - Could anybody recommend a tutorial or point out how to create waves rolling on a beach?
You're welcome to check out my SeaVue tutorial. It uses Monsoon's excellent SeaVue pack to create waves rolling onto a beach.
best, Chipp
forester ( ) posted Mon, 20 August 2007 at 4:19 PM · edited Mon, 20 August 2007 at 4:21 PM
Hi Peggy. Yes I am going to push this to the head of my "to do list" - now that I know that even the pro's do it the way I first made mine. One of the techs was good enough to send me some quick images of their wire frames, and I think I can do something like this, perhaps, with a more reasonable poly count. (Just right after I finish these cornfields and rice paddy models that Christie wanted for C3D. Ugh!) Not to compete with Monsoon's stuff or other techniques. Just to get some good models for reasonable - any persepctive close-up scenes.
Peggy_Walters ( ) posted Mon, 20 August 2007 at 4:31 PM
You can never have too many plants, materials, castles, or waves!  This will complement Moonsoon's SeaVue package perfectly.
Cornfields!  Yeah!!!
forester ( ) posted Mon, 20 August 2007 at 4:37 PM
Totally OFF-Topic
forester ( ) posted Mon, 20 August 2007 at 4:38 PM · edited Mon, 20 August 2007 at 4:39 PM
The denser stuff, with independent rows and indendent component parts... and the high-resolution stalks (with corn ears) are on their way. Thanks for the encouragement, Peggy, I needed that!
Peggy_Walters ( ) posted Mon, 20 August 2007 at 6:23 PM
Looks great!
ellocolobo ( ) posted Mon, 20 August 2007 at 10:18 PM
A very good, cheap and easy way to make good sea scapes is:  produce a simple mountain..Strech it on the x and lower the y until you get the size of waves you want..Apply a water material..Open the beer and surf..
dburdick ( ) posted Tue, 21 August 2007 at 10:53 AM
Here's an example of using SeaVue along with Vue's new layered material capabilities to create larger roiling type seas.  I smudged the wave top foam a bit in PSP, but the wave terrains and materials are all standard SeaVue.
Peggy_Walters ( ) posted Tue, 21 August 2007 at 11:11 AM
That looks fantastic!  I've got to find some time to play with layered materials!
chippwalters ( ) posted Tue, 21 August 2007 at 12:28 PM
Now, all you need to do is add a bit of turbulence. (just kidding!)
Looks great :-)
forester ( ) posted Tue, 21 August 2007 at 6:34 PM
Yes, an excellent composition and rendering! Good for you!
