Sat, Jan 11, 1:35 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 09 9:55 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: creating a point at the intersection of 2 edges?
anxcon ( ) posted Fri, 14 September 2007 at 1:01 PM · edited Sat, 28 December 2024 at 5:49 AM
so i'm trying to make a model, and for simplicity lets say its a tic-tac-toe shape =P
4 edges are made, and layed so  it looks like a tic-tac-toe board, but my question is
how do i made a vertex at each of the points that the edges intersect?
Reddog9 ( ) posted Fri, 14 September 2007 at 3:22 PM
I think for me the fastest way would just be to loop cut each line, eyeball it as close as possible, and then merge the vertexes.
I just looked at using a boolean op, but it doesn't see to work well for just edges.
If someone else has a better method, I'd be interested in hearing it as well.
Good luck.
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
ysvry ( ) posted Fri, 14 September 2007 at 7:08 PM
id say use the multi cut funtion om multiple lines at once.
for some free stuff i made
and for almost daily fotos
jestmart ( ) posted Fri, 14 September 2007 at 9:54 PM
I got this from searching at BlenderArtists forums.
Geom Tool : it makes geometric operations (intersection, projection ...).
http://www.hybird.org/~guiea_7/scripts/geomtool.zip
ysvry ( ) posted Sat, 15 September 2007 at 10:46 PM
thx thats handy tool does it work ok?
Touchwood ( ) posted Sat, 15 September 2007 at 11:38 PM
Trying this out at the moment. Aligning verts works fine and as expected but it looks like when doing alignment to face or edge, if you select a face or edge and multiple verts, it keeps asking you to select an edge. If you just select an edge/face and a single vertice it works OK. I may be not be using it properly though. For me, the vert alignment option is worth the installation, better than other systems I've tried.
