Wed, Mar 4, 12:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 02 11:12 pm)
Subject: Help with "bones" :)
geep ( ) posted Thu, 20 September 2007 at 10:14 PM
Ok, it would appear that you have the "Untitled" prop SELECTED when you do the "Point At..." thingie ...
DO NOT DO THAT !!!
Make sure you have the MAIN CAMERA SELECTED BEFORE you do the "Point At..." thingie.
It would appear that you have caused the "Untitled" prop to move out of it's correct position in the chain ... no???
dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 10:15 PM · edited Thu, 20 September 2007 at 10:17 PM
Sorry ............... didn't mean to yell ................... that loud, anyway. :woot:
dg
I'll be back in a few minutes ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 10:21 PM · edited Thu, 20 September 2007 at 10:21 PM
I don't use that camera control thing. I use the 3 icons above the scene window (see image).
I tried those controls you have pointed to, but nothing happens.
I'll just work with it at this large size and just move it left and right as I need to.  When it's finished I'll just rescale it to a more usable size.
Acadia ( ) posted Thu, 20 September 2007 at 10:26 PM · edited Thu, 20 September 2007 at 10:32 PM
By the way, shouldn't you be in bed?  It's late.  I'll just carry on making my individual names and we can pick back up tomorrow.
Scoot! Go get some sleep :)
EDIT: I solved my problem of having to scroll so far to the right. I deleted some of the props!  LOL I now have 12 props for a total of 24 links. I still have to scroll, but not all that much.
geep ( ) posted Thu, 20 September 2007 at 10:38 PM
Let's contimue for a while if you're going to be up ... yes, no ... maybe?
dg
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 10:48 PM
Yes, I'll be up for hours yet.  Total insomniac here :)
I finished separating the names into unique names and deleted the "link" and "clink:' groups.
geep ( ) posted Thu, 20 September 2007 at 10:54 PM
Excellent !
How about this image?
dg
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 10:58 PM · edited Thu, 20 September 2007 at 11:01 PM
Anyhow, let's continue ...
Check list:
  1. Are all the props in their correct positions relative to each other?
  2. Are all the links in different groups with unique names?
If yes to both of the above questions, then we can "glue" (Export >>> Import) all of the props together.
Are we ready?
dg
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 11:06 PM
I just went through all of the "props" listed and looked at the grouping tool.
For each prop of 2 links, when I select the first name in the Grouping Tool IE: "1", both links are red.  When I select the second name IE: "2", only that link is red.  Is that how it's supposed to be? If so then I'm ready for the next step :)
geep ( ) posted Thu, 20 September 2007 at 11:07 PM
No, that is not correct ...
but we are VERY close.
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:12 PM
Use the GT ... and do this.
  1. Select group "1" ........... (both links are RED)
  2. Click the "Remove Group" button and click the small arrowhead to popup the list of groups
  3. Click on the "2" to remove it from the "1" group
Ok?
Now, the "1" group should only have the first (left) link in it
... and ...
The "2" group should only have the second(right) link in it.
Ok?
dg
We only want ONE link in each group>
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 11:17 PM · edited Thu, 20 September 2007 at 11:22 PM
Ok, I went and did that for all of them and now when I click on each name in each group only 1 link is red at a time.
EDIT: By the way, I'm sorry that this is taking so long. I'm not the brightest bulb in the store when it comes to learning computer things.  Frankly I'm amazed that I've gotten this far on this, or that you have had the patience to stick with me this long :)
geep ( ) posted Thu, 20 September 2007 at 11:26 PM
No problem ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:27 PM
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 11:27 PM
Yep, that's what mine looks like now :)
geep ( ) posted Thu, 20 September 2007 at 11:28 PM
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:29 PM
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
Ok?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:31 PM
Good ... now we can "glue" all the props together ... do you remember how?
dg
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 11:35 PM
Export as a wavefront object?
geep ( ) posted Thu, 20 September 2007 at 11:37 PM · edited Thu, 20 September 2007 at 11:38 PM
Ahhh .... you learn well, grasshopper.
dg
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:40 PM · edited Thu, 20 September 2007 at 11:45 PM
We don't want to waste all our hard work making groups ...................... do we? ... :blink:
dg
CAUTION ... BEFORE we delete all of the individual props ...
Let's import out "Untitled" object and make sure it has all the correct groups, ok?
Good idea, what? ... yes, no, maybe ... ???
Hint:  Go through the individual props and make them NOT "Visible" on the "Properties" tab.
NOW, let's import our "Untitled" prop as follows...
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:48 PM · edited Thu, 20 September 2007 at 11:49 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 20 September 2007 at 11:49 PM
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Thu, 20 September 2007 at 11:52 PM
Ok. I imported it back and the grouping tool shows "1" and "2" in the drop down area.
geep ( ) posted Fri, 21 September 2007 at 12:00 AM · edited Fri, 21 September 2007 at 12:04 AM
Uh oh ... it sounds like you didn't Export ALL of the props ... ??? ** Did you only "Export" the "Untitled" prop?
We need to include ALL of the props that have links when we export the OBJect..
You didn't delete them? ............................................. Did you :blink:**
dg
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Fri, 21 September 2007 at 12:03 AM
I only did the test one that you mentioned above....I made all of the others "not visible" in the parameter dials.
But I'll go and make it all visible again and export and import the whole thing.
Acadia ( ) posted Fri, 21 September 2007 at 12:06 AM
Ok. I finished importing and looking in the grouping tool and I have only the numbers 1 through 24 showing.
geep ( ) posted Fri, 21 September 2007 at 12:06 AM
YES ... Go for it !!!!
We are getting VERY close to making some "bones" ... and, Is that not the "name of the game?" ... or, at least, this thread? (lol)
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Fri, 21 September 2007 at 12:09 AM
hehe. Yep. It's all about bones.
I'm tired. Can we carry on tomorrow? I want to finish up something I was working on early and then head to bed shortly because I have an early physiotherapy appointment on Friday.
geep ( ) posted Fri, 21 September 2007 at 12:09 AM · edited Fri, 21 September 2007 at 12:11 AM
Acadia,
Before we do anything else, ...
SAVE the prop that you just imported in the Props Library of your choice.
We will continue mannana (tomorrow) ... a little Spanish there. ;=]
Sleep well and congrats on  a job well done ... so far.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Fri, 21 September 2007 at 12:11 AM
Ok. I have it saved in props :)  And thank you again for showing me how to do this. I can't believe I'm actually on the way to making my very first model of something, even if it is only aping what you have shown me!  :)
Night :)
geep ( ) posted Fri, 21 September 2007 at 12:12 AM
G'night.
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 8:58 AM
**Good Morning ! **It's Friday ... already.  Where did this week go? Let's make some bones about it, shall we?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 9:07 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 9:47 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 10:12 AM · edited Fri, 21 September 2007 at 10:13 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 10:45 AM
cheers,
dr geep ... :o]
edited 10/5/2019
amy_aimei ( ) posted Fri, 21 September 2007 at 12:39 PM
I wonder if we put IK on the chain will make it easier to pose or not.
geep ( ) posted Fri, 21 September 2007 at 1:53 PM
Hi Amy,
That is a good question ... and the short answer is ... YES!
First, we need to add "bones" to our figure and then ...
... we can create an IK chain for our chain figure.
Thanks for asking.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Acadia ( ) posted Fri, 21 September 2007 at 3:49 PM
Ok, I'm back :)  I'm also caught up. I now have a "figure"... at least in Poser, hehe  Still working on mine though :scared:
geep ( ) posted Fri, 21 September 2007 at 6:14 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 6:29 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 21 September 2007 at 6:52 PM
cheers,
dr geep ... :o]
edited 10/5/2019
