Tue, Feb 11, 8:13 AM CST
Subject: Ati -- Opengl problem
bof ( ) posted Sun, 04 November 2007 at 9:25 AM · edited Thu, 06 February 2025 at 3:57 AM
Hi!
My video card is ATI Radeon X1950 and when i install a new version of catalyst driver 7-10
all my 3d program dont show the work space, Poser 6-7, Daz Studio and LightWave but
if i go back to the version 7-4 everything work. I have the same problem with my second
machine Ati Radeon X850. If i select sreed in poser it's work but ugly...
Someone know a way to fix that .
Thanks!
Sorry my bad English.
bof ( ) posted Sun, 04 November 2007 at 9:34 AM · edited Sun, 04 November 2007 at 9:46 AM
I found something, i have 2 screen if i disable the 2 screen everything work.
And i found another thing in my Display properties panel (settings) if i place in order
screen 1 and 2 its work but if i invers screen 2 and 1 its does not work. weird....
My setup is 2 and 1 someone know how to fix that..
Thanks!
pakled ( ) posted Sun, 04 November 2007 at 10:40 AM
might check the resolution on each screen. Recently had someone who tried to have a 640x480 screen (don't ask...;) and the screen wouldn't show until you bumped it up to 800x600...;) refresh rate, resolution, color depth, each can have a varying amount of impact on the monitors (not all that much, to be honest...;) just a thought.
bof ( ) posted Sun, 04 November 2007 at 11:25 AM
Both screen is set to 1680 X 1050 32bit and the same refresh rate..
Thanks!!
Gareee ( ) posted Sun, 04 November 2007 at 2:14 PM
Might be a bug with the 7-10 driver.. maybe try the 7-9 driver?
I'm running a x1950 pro here with 512 meg, and was recently running one with only 256 meg, and both ran fine on the new driver.
Maybe use the ati driver removal utility, and then install the 7-10 fresh without any old junk sitting around?
wdupre ( ) posted Sun, 04 November 2007 at 2:48 PM
I have found that running dual screens on even an advanced card tends to cause glitches with software that uses open GL for its display rendering specifically if you have multiple open gl software open at once. This has been true in my experience on several computers with both ATI and Nvidia cards. what I have seen mimics pretty much what you are discribing, that the workspace simply copies whatever is underneath it rather then displaying your scene.
bof ( ) posted Sun, 04 November 2007 at 2:57 PM
@Gareee
I try with older driver (7-5 to 7-10) with the same problem the only one work fine is 7-4
i can change the order of my screen without problem...
Thank !!
Gareee ( ) posted Sun, 04 November 2007 at 5:21 PM
Simple solution then: install the new driver, swap the cables going into your monitors, and then swap them in preferences since you said that worked properly.
onnetz ( ) posted Sun, 04 November 2007 at 5:38 PM
another problem with the new ati catalyst drivers is that cli.exe will clone itself many times and you might find your system very sluggish..
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
Gareee ( ) posted Sun, 04 November 2007 at 5:44 PM
That's the first time I've heard of that, and I'm running the new UT3 demo, and the new crysis demos at blazingly fast speeds with the 7-10 driver.
Once caution about x1950 pros though... check them monthly for dust buildup.. .I think I cooked my old one. it had clogged the air intakes of it's cooler channels with dust, and when I removed it to clean it, I'd say that perobabl 50% of the channels were packed with dust! The card was running very hot for some time, and while it still works, it does lock up now when put under heavy game or 3d use.
Good thing it, it's still under warranty.
bof ( ) posted Sun, 04 November 2007 at 6:20 PM
Quote - Simple solution then: install the new driver, swap the cables going into your monitors, and then swap them in preferences since you said that worked properly.
HAHA!! simple but I had not thought has that (i feel a little bit stupid...)
Thank you Gareee
Gareee ( ) posted Sun, 04 November 2007 at 7:15 PM
Sometimes the simplest solutions are the easiest. I had 2 of the same brand/model monitors and a similar issue, I think.. it might be a windows issues because they are identical and hydravision confuses them.
After a few hours of trying to figure out why things weren't working properly, I just figured screw it, shut the system off, swapped the monitor cables on the video card, fired the system up, and I was good to go.
