Wed, Jan 22, 6:08 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 22 5:47 pm)
Subject: Splotches :-(
Lighthorse ( ) posted Sat, 17 November 2007 at 1:48 PM · edited Wed, 22 January 2025 at 6:07 PM
This is Aymee for V4 ( not supposed to have freckles) Do not know were they are coming from. I get this splotching on a lot of  the V4 Textures Some even get  a shiny plastic look.
I did not have this problem before. After installing all my plugins it started happening.
Any ideas on what can be causing it.
Oh yea I am using Daz 1.8
Lighthorse
FalconArts.Com
RHaseltine ( ) posted Sat, 17 November 2007 at 4:20 PM
Is that a render or the preview? If it's a render, what are your settings?
Lighthorse ( ) posted Sat, 17 November 2007 at 4:44 PM
That is both the preview and render.
I just did a quick render to show the preview.
That is how the Skin looks when applied and in render using a veriaty of settings.
Lighthorse
FalconArts.Com
Khory_D ( ) posted Sat, 17 November 2007 at 8:51 PM
This is a long shot but could it be the bump settings or a bump map ending up on a displacement map? Try a closer render with the the focal distance on the camera you use changed to about 100.
www.Calida3d.com
Daz studio and Poser content creators
Lighthorse ( ) posted Sat, 17 November 2007 at 9:45 PM · edited Sat, 17 November 2007 at 9:57 PM
The Problem came when I Instaled all my plugins.
before that the skin texture was normal.  I do not know which
would cause this but before all was fine.
I just checked It only happens to a few skins
( It would take some time to check them all).
If someone else has Aymee
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=57673
I wonder if they are having
the same problem ? I looked at the the files and the skin
is smooth and well done ther is just something about it that Daz
is not seeing properly.  ???
Lighthorse
FalconArts.Com
Lighthorse ( ) posted Sat, 17 November 2007 at 10:14 PM
OK, well if I do a render as in finished image Render is fine.
My problem now is why with a few of my skins the preview looks so bad :-(
Lighthorse
FalconArts.Com
RHaseltine ( ) posted Sun, 18 November 2007 at 9:34 AM
The preview uses a smaller version of the texture (there's a slider in Edit>Preferences>Interface to control how much smaller). If the downsampling happens to hit the frequency of the pattern in the skin or other texture in the wrong way you will get interference patterns.
Lighthorse ( ) posted Sun, 18 November 2007 at 10:19 AM
What I mean as preview is as you see it in th work aera and as you are working on the scene.
once sampled using the higher settings it looks fine but the quick render and skin tex that you
see while working on the figure look terrible. I have noticed that it is mostly happening on
the higher res textures.
Lighthorse
FalconArts.Com
lthemer ( ) posted Sun, 18 November 2007 at 5:12 PM
If you have ambient occlusion on in the quick render, but with a low sample value, you'll get a lot of splothing. May be that's is.
Sam
