DAZ|Studio F.A.Q (Last Updated: 2025 Feb 02 12:10 am)
The Problem came when I Instaled all my plugins.
before that the skin texture was normal. I do not know which
would cause this but before all was fine.
I just checked It only happens to a few skins
( It would take some time to check them all).
If someone else has Aymee
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=57673
I wonder if they are having
the same problem ? I looked at the the files and the skin
is smooth and well done ther is just something about it that Daz
is not seeing properly. ???
Lighthorse
FalconArts.Com
What I mean as preview is as you see it in th work aera and as you are working on the scene.
once sampled using the higher settings it looks fine but the quick render and skin tex that you
see while working on the figure look terrible. I have noticed that it is mostly happening on
the higher res textures.
Lighthorse
FalconArts.Com
I did not have this problem before. After installing all my plugins it started happening.
Any ideas on what can be causing it.
Oh yea I am using Daz 1.8
Lighthorse
FalconArts.Com
