Personally, I've found Modo to be the easiest, most intuitive modeler out there, but I've never used Max or Hexagon. What works best depends a lot on the user. Max should be capable of any task. The jewelry you've posted would be really easy to create in Modo but if you’ve already invested a small fortune in 3dsMax, it might be worthwhile to figure out how to do it in that program.
I know it would be easy in Hexagon... Draw the curly things with the
splined-polyline tool. Apply a Thickness to each, with 8 sides. Draw
circles for the main rings, apply Thickness to them. Use the Deformer
to curve the curly pieces slightly so they fit against the arm. Then arrange
and scale the pieces around an actual arm (exported from Poser) and weld.
(Note: I'm actually thinking in Amapi here, but since Hexagon is derived
from Amapi, the directions should still work.)
My python page
My ShareCG freebies
easier yet would be to model a cylinder and using a texture draw the curves in white with a smoothed brush against a black background and use that as a displacement map. A transparency map to clear out the "hollow" parts.
Could be done in minutes in Photoshop, or in the Gimp.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Another method in 3ds Max is to draw the curly segments with 2D splines, then create a simple cube. Got to polygon sub-object mode, select the necessary facet and choose "extrude along spline". Just click the spline you created and you'll have the general shape you want. Add a turbosmooth modifier to finish things off.
That's just me, there's a lot of ways to skin a cat :)
I use Max and would just lay in some splines and then make them renderable in the parameters tab, you can adjust thickness and side counts. Also lofting would work too, giving you the ability to easily alter the size and thickness of the spline where ever you wanted to...good luck!
Cool, Posette has a new torque using this method and the poser primative cylinder!
