Thu, Jan 23, 12:27 PM CST
Subject: The Redeye Effect
ghoyle1 ( ) posted Thu, 20 March 2008 at 3:22 AM · edited Thu, 23 January 2025 at 12:24 PM
No, I'm not trying to get rid of it in a photograph, I'm trying to create it in Poser 7. Any suggestions on how to create this effect in the Materials room?
Thanks,
Guy
vince3 ( ) posted Thu, 20 March 2008 at 4:58 AM · edited Thu, 20 March 2008 at 4:59 AM
have you tried editing your texture map (copy) , so that you have a red colourized pupil area?
you could just add a circular red spot to your copy of the tex map and adjust the opacity slightly so that it is not a solid red, before merging layers.
if it is just a still image, then why not just add it in postwork?
lkendall ( ) posted Thu, 20 March 2008 at 7:41 AM
3/20/08
Do you mean a red pupil?
LMK
Probably edited for spelling, grammer, punctuation, or typos.
thundering1 ( ) posted Thu, 20 March 2008 at 9:13 AM
If you're going to do it in post, get a real photo (or take one) with bad red-eye and use that.
Can't get any more real than that.
Hope that helps-
-Lew ;-)
dadt ( ) posted Thu, 20 March 2008 at 9:28 AM
In the Material Room select the pupil then disconnect the Image Map node from the diffuse colour box and change the diffuse colour to red.
ghoyle1 ( ) posted Thu, 20 March 2008 at 3:54 PM
Thanks for the suggestions. I'm trying to do it all within Poser, not postwork, but I'm still playing around with the effect.
Guy
Miss Nancy ( ) posted Thu, 20 March 2008 at 4:35 PM
in humans, the pupil is the opening in the iris, hence it's just an empty space surrounded
by a circular muscle.  the red-eye fx is the flash illuminating the human retina.  but then,
I reckon poser figures must have a black pupil that's opaque, otherwise we'd see default
renders with both nostril glow and "retina glow" 🤣
thundering1 ( ) posted Thu, 20 March 2008 at 4:49 PM · edited Thu, 20 March 2008 at 4:49 PM
Miss Nancy - your avatar has grown!
Exactly - it also has different hues - not just a blank red dot which will look cartoonish. I'm afraid that if it is made a "material" how much gets lighted/you will see will depend entirely on the lighting (unless the Materials Lab has a Luminance Channel - I'm blanking).
The closer a flash is to the lens, the more reflection you will get from the retina - which is why we only see it through the pupil.
I'm still thinking your best bet is postwork if you want it to look real - and years of family and friends' photos would be an almost endless supply.
bagginsbill ( ) posted Thu, 20 March 2008 at 5:39 PM
Try this thread:
Cat's Eye Glow in Animation
The issue there was a cat's eye (green) not human, but the principle is the same.
I then tried it in an animation - the Poser cat's eye is not shaped great for this, but you get the point. It might work on your figure. Be aware that many figures have a cornea bulge morph. You may need to use that to improve the results.
Click here for the animation
thundering1 ( ) posted Thu, 20 March 2008 at 6:04 PM
That's funky!
ghoyle1 ( ) posted Fri, 21 March 2008 at 2:35 AM
This is pretty close to what I'm looking for. Thanks for the heads-up, Bagginsbill!
Guy
