I've tried it and it does work with 2 gigs of RAM. Poser wasn't running (If I remember correctly) However.....the changes I made were small (arm position) and it did gobble up the memory. The reason I say poser wasn't running is that although I have version 7, Vue still looks for V6 which wasn't/isn't on (it's not there anymore). But it does work like a charm. Also if you want to try it with 1G shut down everything that you don't need and give it a go. Trepz, you should get it working if you tell it so. Now I'll have to go do it again and see what else is needed. But if I remember correctly the dialog on the initial load was all I needed.
*"Group figures as single meshs"
*Yep, don't do that!
Poser can be open or closed, it makes no difference!
I never repose inside Vue, it's too cumbersome, I leave Poser open with the same character open also and re-pose there, then re-save. If you do it that way, Vue will tell you it's been changed and ask if you want to re-import it, much easier than re-posing inside Vue!!
And, here's the bonus; Even if you've moved the character around the World in Vue, when you re-import, Vue plonks it down where you have it rather than the default import position, how cool is that!!!!
Injustice will be avenged.
Cofiwch Dryweryn.
Don't even try using re-poser inside of Vue - its way too slow and error prone. The best thing to do when you want to repose is to just fix the pose in Poser and re-save. It will then ask to re-import in Vue. Yes, it will trash all of your materials which is why you need to get the posing done first before applying material changes (e.,g SkinVue).
I put a feature request into the e-on folks to do a "re-import Geometry only" which would preserve all the materials and just re-import the geometry. If they had this, you would never need the re-poser anyway.
I try to pose in Poser to the best of my ability however quite often I still need to adjust the pose to fit with the rest of the scene. I did try posing in Vue which worked but its not set up the same and it eats resources. so i basically I follow the same work flow as Thefixer.
As for the problem having to repeat the skinvue setup - you can save the setting for the body and for the eyes within vue , so when you reimport from poser you just need to reload these 2 settings.
The problem is I often change features of the skinvue material in the function editor and if I repose and reimport I have to repeat that.
So it would indeed be much nicer if there was an option to reload geometry only, without materials, I hope they incorporate it.
"I paint that which comes from the imagination or from dreams,
or from an unconscious drive. I photograph the things that I do not
wish to paint, the things which already have an
existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
Vue will re-import geometry after you change them, but only from Object files, (OBj, 3ds, etc). Also I import poser as single meshs. It sems to cut down on memory use. It works fine.
Trepz, I can't see what you are doing that's any difference from me. I haven't had any use for the Poser Shader Tree, though so haven't tried that.
Just a thought, when you load the PZ3 file after the import screen a second screen should appear. It asks if you want to disable Poser reposing. The answer is No. Did you see that screen? It's like a test on a Federal Exam, no really means yes (you want to use Poser).
This really would be a handy new feature. I had changed a load of materials in a scene recently but I had to go back to Poser to adjust the pose. Damn, I had to save all my material settings first because I knew they'd be lost on the re-import. Then I had to load all my new materials when I was back inside Vue. What a pain.
Trepz - I just tried it again to make sure I remember correctly. Your problem is the tick on the box 'group figures as single meshes' If have a single mesh there are no groups in it and thus you cant repose. remove the tick, you'll get a second screen to respond to and then you'll get the figure with each body part as a group. You should be able to repose then.
In my screen capture I imported the same figure twice - once as 'single mesh' and one not a 'single mesh. The first only has one item -body:1, the other has all the body parts in the list.
Good luck, but I still dont think its worth doing it this way.
existence."
existence."
Quote - Also too slow to be usable with a G5 2GHz.
Also too slow with a quad Core 2 2.4 GHz with 8GB of RAM. But it does work if you have a lot of patience.
I pose in Poser and render in Vue. I find if I pose each small portion of the scene in Poser I can then transplant it into the larger set since it tends not to interact with things that are distant.
AMEN to 2ni and Mycat.
I have found it is only good for small things such as moving a hand or a leg a small amount to make it fit or interact with an object that I already have loaded in View. But it does work.
By the by to ArtPearl: even if you import as a single mesh, you can still change poses. As 2ni stated simply click on either the mesh figure in your view window or on the object listing. It brings up a dialog window that will let you access all the joints. They are listed in a wierd way but they are all there.
Finally going to try and play with V4 inside Vue with the Poser shade tree and reposing ect.Is there a set of paramaters you have to folllow inside Vue? Does Poser have to be running while you tweak it? Is there a step-by-step anywhere on how to do all of this?
"Many are willing to suffer for their art. Few are willing to learn to draw."
