Wed, Feb 26, 8:52 AM CST
Forum Moderators: RedPhantom
Subject: Any character with both face and body maps in one single map?
ikercito ( ) posted Fri, 16 May 2008 at 10:12 AM · edited Wed, 05 February 2025 at 3:57 PM
Hi all!
Just out of curiosity, is there any character with face and body shaders sharing one single map? To clarify, both materials require only one single map, i mean one  jpg with the face and body in it...?
Thx!
nyguy ( ) posted Fri, 16 May 2008 at 10:27 AM
Posette comes to mind and I think V2 (been so long since i had looked at a map for her).
Poserverse The New Home for NYGUY's Freebies
momodot ( ) posted Fri, 16 May 2008 at 10:53 AM · edited Fri, 16 May 2008 at 10:54 AM
The Poser 4 figures called Posette and Dork usually. It would not be to hard to put the textures for Millenium 2 or 3 figures on one map using the free UVmapper Classic utility.
JoePublic ( ) posted Fri, 16 May 2008 at 11:46 AM · edited Fri, 16 May 2008 at 11:47 AM
Attached Link: http://aprilsvanity.com/dlpage.php
AprilYSH has a remapped Vicky 2 that can use Posette textures, so she has body and head materials on a single map, too.
ikercito ( ) posted Fri, 16 May 2008 at 12:08 PM
Oh God! I forgot about Posette! You're all right!
Posette always at hand :D
Momodot, could you explain briefly how you'd do it with Uvmapper? I was thinking about it, but never been too good with UVs...
Thanks guys.
Tashar59 ( ) posted Fri, 16 May 2008 at 3:00 PM · edited Fri, 16 May 2008 at 3:03 PM
IN UVMapper,all you would have to do is select by Material and resize and move all the materials to fit on the map instead of being on top of each other. Then save out the new .obj and uv template map to work on.
You would have to create new textures for the figure or use a paint program and match the old textures to fit the new uv map.
ima70 ( ) posted Fri, 16 May 2008 at 5:47 PM
Sixus1 Proyect Human female, female lores and male have head and body textures in one map
http://www.sharecg.com/pf/Sixus1Media?PSID=b6f335fbb4f3ac2b14cb3e175b3f9961
replicand ( ) posted Fri, 16 May 2008 at 6:38 PM
 A while back I was remapping Mil 3 characters so that the skin textures were on one map (for physical SSS) but I kept the transmaps separate
momodot ( ) posted Sat, 17 May 2008 at 3:11 PM
The way I have done it in UVmapper Classic is to select on the body map elements as a group and size the marquee down to 50% and place it to the bottom of the map and then do the same for the head elements moving them to the top of the map... then saving the model and the template. If you do it right then you can make the new one-piece texture by just doubling the height of the head texture canvas and pasting the body texture below it and saving this combined texture. You can check your placement by loading UVmapper with the combined texture as a background to the UVmapper wireframe display.
