Forum Moderators: RedPhantom
Posette comes to mind and I think V2 (been so long since i had looked at a map for her).
Poserverse The New Home
for NYGUY's Freebies
Attached Link: http://aprilsvanity.com/dlpage.php
AprilYSH has a remapped Vicky 2 that can use Posette textures, so she has body and head materials on a single map, too.IN UVMapper,all you would have to do is select by Material and resize and move all the materials to fit on the map instead of being on top of each other. Then save out the new .obj and uv template map to work on.
You would have to create new textures for the figure or use a paint program and match the old textures to fit the new uv map.
The way I have done it in UVmapper Classic is to select on the body map elements as a group and size the marquee down to 50% and place it to the bottom of the map and then do the same for the head elements moving them to the top of the map... then saving the model and the template. If you do it right then you can make the new one-piece texture by just doubling the height of the head texture canvas and pasting the body texture below it and saving this combined texture. You can check your placement by loading UVmapper with the combined texture as a background to the UVmapper wireframe display.
Hi all!
Just out of curiosity, is there any character with face and body shaders sharing one single map? To clarify, both materials require only one single map, i mean one jpg with the face and body in it...?
Thx!
