Fri, Jan 31, 11:48 AM CST
Forum Moderators: Staff
Subject: Why is this happening?
nyguy ( ) posted Tue, 27 May 2008 at 7:24 PM · edited Fri, 31 January 2025 at 11:45 AM
Okay when I render my model I get this weird looking render but looks good in preview. Checked the mapping and it is correct. Can anyone tel me how to fix?
Poserverse The New Home for NYGUY's Freebies
Here is what it looks like in preview
markschum ( ) posted Tue, 27 May 2008 at 9:35 PM
what did you model it in ?  some of that could b non-planar polygons or flipped normals .
nyguy ( ) posted Tue, 27 May 2008 at 9:54 PM
Max 7
svdl ( ) posted Tue, 27 May 2008 at 9:59 PM
Poser does not like n-sided polygons (n>=5). I always use UVMapper Pro to triangulate anything that's not a tri or a quad.
UVMapper Pro can cneck for degenerate and non-planar facets and fix the problem by triangulating them. I'm not sure whether the free version of UVMapper can do this too.
My gallery   My freestuff
nyguy ( ) posted Wed, 28 May 2008 at 11:49 AM
Quote - Poser does not like n-sided polygons (n>=5). I always use UVMapper Pro to triangulate anything that's not a tri or a quad.
I have UVMapper Pro but could not figure out how to check for non planar facets or degenerate ones.
svdl ( ) posted Wed, 28 May 2008 at 2:59 PM
It's in Tools->Facets, if you chose "Concave" itl'll scan for concave facets and triangulate them as needed. Same for Tools->Facets->Degenerate.
nyguy ( ) posted Wed, 28 May 2008 at 10:37 PM
Doing as suggested made it worse
kuroyume0161 ( ) posted Wed, 28 May 2008 at 10:51 PM
Weld or Split vertices in UV Mapper Pro maybe?
 -- Bjarne Stroustrup
xantor ( ) posted Thu, 29 May 2008 at 2:10 AM
If welding or splitting the vertices doesn`t work then it looks like some of the polygons are reversed.
nyguy ( ) posted Thu, 29 May 2008 at 5:45 AM · edited Thu, 29 May 2008 at 5:47 AM
I know none are reversed due to converted it to double sided at one point to see if that fixed it. Here is a render of it in D|S it is not as noticeable there.
nyguy ( ) posted Fri, 30 May 2008 at 12:06 PM
Wish to thank Khai for helping me fix this. Easy fix is to go into the Material room, select texture and click on Normals Forward. Here is a preview. I am working on some textures and remapping.
xantor ( ) posted Fri, 30 May 2008 at 1:29 PM
So it was reversed normals, as I said.
Khai ( ) posted Fri, 30 May 2008 at 1:45 PM
Quote - So it was reversed normals, as I said.
no, it's a double faced surface with a zero thickness.. and has been known about since Poser 5...
the fix in 5 was add a small amount of displacement, 6 and higher have the Normals switch.. Most render engines can allow for it.
and I'm suprised at the names in this thread that did'nt spot it.... as I said.. it's been known for years...
xantor ( ) posted Fri, 30 May 2008 at 2:08 PM
That must have been the same problem I had with the 3dsc fairytale coach (but I don`t know how it got double faced surfaces).
kuroyume0161 ( ) posted Fri, 30 May 2008 at 2:51 PM
Hey Khai, I'm callin' you out!  (just joking) :D
I have rarely (if ever) encountered this in Poser so it didn't register but it is mentioned in B L Render's book.  Really, without the obj file to examine it could have been ngons, normals, degenerate polygons, double-sided polygons, need for welds/splits (which is a common problem resulting in odd shading results), and so on.
Hopefully that solves it! :)
dennisharoldsen ( ) posted Fri, 30 May 2008 at 3:49 PM
nyguy:
i'm surprised that  svdl didn't mention that he has a script that changes all the normals forward in a scene at once.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3171555&ebot_calc_page#message_3171555
nyguy ( ) posted Fri, 30 May 2008 at 4:23 PM
Well I had just uploaded it to my website and it is live for downloading. I will be working on textures later right now I gotta play with my son for a few.
To download click on my banner and click freebies.
xantor ( ) posted Fri, 30 May 2008 at 6:15 PM
Great, thank you.
