Sat, Jan 25, 6:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Explosions
Anthony Appleyard ( ) posted Thu, 05 June 2008 at 3:24 PM · edited Sat, 25 January 2025 at 6:35 PM
Please what 3D CGI models of explosions are available?
mrsparky ( ) posted Thu, 05 June 2008 at 4:22 PM
Attached Link: http://www.sparkyworld.org/images/gallery/fx_l_apache.jpg
Helgard has a free python script at VP, Phil C has a commerical one at his site, both allow you to explode a mesh in various ways.
Powerage has a range of exploding buildings.
Or you could try using Foresters water splahses and using them as "particles" of dirt.
All of these do miss one thing though - the dust cloud or the middle explosion bit - for that you need to postwork it.  I find Particle Illusion for that as shown in the image (given in the link above) is the best way.
muralist ( ) posted Thu, 05 June 2008 at 4:55 PM
For the dust cloud and middle explosion, go get a loop of frames of an explosion and make an avi texture on some planes.  Works great.  You can either use a static plane, or get fancy with it and apply the animated tex to some particles for good effect.
muralist ( ) posted Thu, 05 June 2008 at 5:24 PM · edited Thu, 05 June 2008 at 5:38 PM
Anthony and Helgard, check Detonation films.  Great stock fx clips already in avi format.  The mirror download is much faster.  (Also check out their tutorials sectioon.)
http://www.detonationfilms.com/free_stuff.htm
Doctor Destruction ( ) posted Fri, 06 June 2008 at 8:26 PM
This explosion is from a television show I did a little while back.  Hope this helps if you want to make a Poserized explosion or something.
  • DrD
flibbits ( ) posted Sat, 14 June 2008 at 2:13 PM
What is VP?
Helgard ( ) posted Sat, 14 June 2008 at 2:59 PM
VP is Vanishing Point, another website that sells models and stuff.
Muralist, I have all the clips from Detonation Films, and I also boaght loads of clips from Artbeats. The Artbeats clips are much higher quality, but they are not free. I will put up the video sometime when I finish it of the depth charge explosions animations I have made.
Your specialist military, sci-fi, historical and real world site.
rjandron ( ) posted Sat, 14 June 2008 at 3:59 PM
Anthony, I would second mrsparky's suggestion of looking at Wondertouch's Particleillusion, which can be used to generate any number of explosions. It takes a fair bit of work to remap some colours on their presets, but you can get 2D explosions which are every bit as good as the ones at Artbeats.
