Mon, Nov 18, 10:21 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 18 2:47 am)
Subject: Texture Problem
sapphy ( ) posted Wed, 13 August 2008 at 10:55 PM ยท edited Mon, 18 November 2024 at 9:00 AM
Hello, I have a problem with a texture set I created for Daz Studio. When applied it shows as all white but it renders correctly. I can't find anything wrong but I'm not sure why it does this.
Any help is appreciated :-)
Sapphy
RHaseltine ( ) posted Thu, 14 August 2008 at 9:31 AM
Online Now!
Is it only your texture set that does that? What format are the images in? What size are the files?
sapphy ( ) posted Thu, 14 August 2008 at 10:50 AM
It is only one of the textures I made for the A)5 Euphoria Dress, they're in dsb format. I believe the texture itself is 3000x3000. Like I said, it renders correctly but shows white in the preview which is really strange.
RHaseltine ( ) posted Thu, 14 August 2008 at 2:45 PM
Online Now!
.dsb is a script for loading the texture, not the texture itself.
sapphy ( ) posted Thu, 14 August 2008 at 3:15 PM
I'm sorry, they are in jpeg format.
RHaseltine ( ) posted Fri, 15 August 2008 at 2:28 PM
Online Now!
Does the texture work (as in produce a visible effect - it will look weird) if you apply it to another model, suc as one of the primitives?
sapphy ( ) posted Fri, 15 August 2008 at 2:47 PM ยท edited Fri, 15 August 2008 at 2:47 PM
I'll try that and post a pic
sapphy ( ) posted Sat, 16 August 2008 at 12:52 AM
I believe it has something to do with the transparency map. When I take the transparency map off, it shows correctly in the view window. As soon as I apply the transparency map, it turns white.
This pic is the view window version:
This is the rendered version:
RHaseltine ( ) posted Sat, 16 August 2008 at 8:33 AM
Online Now!
What size and file type is the transparency map, and does applying both to a primitive preview correctly?
sapphy ( ) posted Sat, 16 August 2008 at 10:07 AM
The transparency map is 3000x3000 and the regular texture works correctly on the primitive but the transparency doesn't, it does the same thing. I have redone the transparency map, maybe I'll do it again.
RHaseltine ( ) posted Sat, 16 August 2008 at 2:19 PM
Online Now!
It does sound as if it's an oddity in the image file, since the render and the preview are separate bits of code one could fail when the other didn't. If you are willing it would be a good diea to make a bug report and attach the problem map to it.
