Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
I presume that Vue primitives are not even meshes, but mathematical objects (otherwise I would not know how they would handle blobs) so the "wireframe" is not even defined. It is exactly the same situation as in POV-Ray: all entities but for mesh{and friends are mathematical items and if you go to povray.org you wil see that from time to time people pop up asking for a POV to mesh convertion and the answer is a more or less polite "forget it"...
Bye!!!
B.T.W. it would be EXTREMELY interesting to find a way to render only the wireframe of and imported mesh (e.g. modeled in Hex :biggrin:)
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
If the object is uvmapped, you could always texture the object with the uvmap (not coloured, just the raw uvmap template) and render that. As long as you're uvmap doesn't have overlapping parts of mesh/polys, it should give you pretty much what you want. I've used this technique in bryce a while back (years ago) and it worked ok.
Digital
WasteLanD
And, thinking a bit more about this, if you invert the uvmap template and use that as the transparency map, then you can have only the edges of the polygons that make up the geometry show up - true wireframe (as opposed to the solid wireframe that my post above would give you). You might need a pretty big uvmap template texture thingy to do this with to get sharp edge lines, but then doesn't Vue have some sort of texture caching to allow it to work with really huge texture maps (seem to remember them talking about this in some of the v6i advertising).
edit - forgot that Vue does trans maps reversed to bryce - you may not need to invert it to get the wireframe look.
Digital
WasteLanD
I have a question for you gurus. Do you think there is a way to render an object, say a primative sphere, and have only the geometry rendered and not the skin of it? I realize it is only a mathmatical object and it has no physical skeletal construction, but I know C4d can do it so I was wondering if VUE has that capability. As powerful as the editor is, there has got to be a way.
If anyone could figure it out please post it so we can all learn from it.
