Fri, Dec 27, 4:58 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 26 8:06 pm)
Subject: Torkeeper with aniMate
6R ( ) posted Sun, 19 October 2008 at 9:20 AM · edited Thu, 26 December 2024 at 3:45 PM
Here is my first quick test of a small aniblock I created : A torkeeper !
Very easy to do in Daz with aniMate :
1- I insert V4.
2- With Puppeteer, I give her the first and the final pose. I record the whole animation.
3- I save with the aniTimeline "create aniblock from DS keyframes".
4- Then... New -> I insert another character and objects.
5- I select the character and drag and drop MY "torkeeper" aniblock.
6- I export as .avi file ! Finished !!!
6R
tom271 ( ) posted Sun, 19 October 2008 at 3:36 PM
How do you export your animations to avi...?   I could not find this function in studio...
thank you....
6R ( ) posted Mon, 20 October 2008 at 1:53 AM
With the Tab "Render" (from Daz) : select Make Movie instead of Still image then render to mo vie file(.avi) or image series (.png files) !
6R
Akhbour ( ) posted Mon, 20 October 2008 at 3:22 AM
The best way is to render as a series of images just set the save path in the dialogue and name the picture "myimage_.png" , the underscore shows D|S where to put the number.
Use www.virtualdub.org/ to load the images and save it from there as avi. This way you may delete or add images, or via batch actions apply filters.
Peter
6R ( ) posted Mon, 20 October 2008 at 4:23 AM
Very interesting to select the images before creating the .avi file !!! Thanks !!!
I do the same with Anim Shop 3 before creating  an.avi file or a .gif file but it isn't free !  ;o)
6R
tom271 ( ) posted Mon, 20 October 2008 at 2:37 PM
Just thinking out laud
saving one of those AniBlocks in a series of images must take an hour.. at least...  is this true?
Akhbour ( ) posted Mon, 20 October 2008 at 4:20 PM
Depends on your render settings!
When I do a still render with all bells and whistles, rendertime may go up to 30 hours, Iwould never do that in an animation!
When I do an animation in D|S, the rendertime is between 2 to 5 minutes per frame, so depending an the animationlength, that may take a night.
When you do a still, it easy to see where your lightning is bad, in animation a lot of things are just not seen because of the action, but in any case you need to set up a convincing lightning, instead of 20 spot and pointlight plus some distant lights, you use one spot with raytraced shadows, maybe a point and a distantlight, keep the number of "shadow-lights" as low as possible and prefer raytraced shadows to shadow maps.
Peter
6R ( ) posted Tue, 21 October 2008 at 2:11 AM
To create an aniblock you don't need any lights or shadows !!!
Just V4 for example with different poses to "puppeteer" !
When you want to save your real animation using an aniblock on any character in a scene here you need lights (and shadows)...
It's true ! Depending on your aim : Render can be very long or not !
Create an aniblock and render a scene (picture or animation) are two different things.
Always make export tests with a small resolution 320 x 240 for example and just a few frames of the whole animation by taping 0 to 5 frames for example for the render !
You don't have to export the whole animation at the beginning...
If the first tests are Ok for you then you can export all ! And you can do something else during the calculation...  :o)
A serie of images or an .avi file is the same (I think ?) relative to the duration... because Daz calculates and renders each frame in both cases.
6R
Akhbour ( ) posted Tue, 21 October 2008 at 3:54 AM
Yes, rendering a series of still images or rendering to .avi takes the same amount of time.
Peter
6R ( ) posted Tue, 21 October 2008 at 5:09 AM
Thanks for the precision Akhbour...
6R
