Mon, Jan 6, 9:11 PM CST
Subject: Yet another "Artifact" question.
Boni ( ) posted Wed, 10 December 2008 at 9:48 AM · edited Mon, 06 January 2025 at 8:50 PM
This time with the Infinity Cove ground prop.
I've faced normals forward, smoothed and unsmoothed polygons, removed backfacing polygons ... and a handful of other remedies from a topic search.
This is a WIP, with levels adjusted in Photoshop to clerify the problem.  I'm using P6 with a firefly render and 2 lights, 1 raytraced and 1 sss-shadowmapped.  (adjusting these didn't seem to make any difference.
Any help would be appreciated.  BTW, this always happens with this prop.
Boni
Boni
Boni ( ) posted Wed, 10 December 2008 at 11:46 AM
A second problem I've had for a while that I haven't seen anywhere else.  It involves props and hair ...  When I save a scene and re-open in there is a dialog box that asks for strange geometries ,  "Geo" or "Geometr", "M", "3", "r" or a variety of other labels then since the label doesn't exist the prop doesn't either.  It's rather annoying to have to re-load and adjust the prop in each session.  I've not seen this asked before so I thought I'd throw this weird occurence out there too.  (please excuse my typo's I have a visual impairment and don't catch them all).
Boni
Boni
JOELGLAINE ( ) posted Wed, 10 December 2008 at 4:19 PM
Have you tried exporting the prop with all the normals forward boxes checked on re-import? Have you checked the box in the advanced tab in the Material Room for "Normals Forward"?
If all that works, then save it to the Props Library, and name it what you like, and save it in the scene and stupid ol' Poser won't ask for goofy tags again with that.
I've done that HUNDREDS of times It works with hammering the normals forward.
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
Dizzi ( ) posted Wed, 10 December 2008 at 4:32 PM
Quote - When I save a scene and re-open in there is a dialog box that asks for strange geometries ,  "Geo" or "Geometr", "M", "3", "r" or a variety of other labels then since the label doesn't exist the prop doesn't either.
I'd suggest to do the following:
  1. reapply the latest service release and see if that helps loading from a newly created scene
  2. check the scene file with a text editor to see how the path of the prop looks like in it (is it already wrong in the file or not?)
Miss Nancy ( ) posted Wed, 10 December 2008 at 5:04 PM
boni, can you elaborate on "1 sss-shadowmapped" lite?  when ya say "adjusting these
didn't seem to make any difference", did that include deleting said lite?
nruddock ( ) posted Wed, 10 December 2008 at 5:18 PM
Increase the "Shadow Bias" on any lights you have casting shadows.
Boni ( ) posted Wed, 10 December 2008 at 7:54 PM
Thank you for your responces.
JOELGLAINE:  That sounds like a great idea ofr regular static props.  But some of these are hair props and props with morphs. Will I lose the morphs and such by doing that?
Dizzy:  I suspect that this happens during the save sequence since yes, the path is corrupted in the scene file.
Miss Nancy:  As long as the two lights. (the sss is subsurface scattered in this instance, but it happens with all but a single IBL light when applied)
Nruddock:  I will definately try that. Okay ... it improved a little, but they are still there.  Back to the drawaing board.
Any more suggestions will be very much appreciated.
Boni
Boni
dphoadley ( ) posted Wed, 10 December 2008 at 10:05 PM
Is it possible that you've got two props there, one stacked on top of the other?
DPH
Dizzi ( ) posted Thu, 11 December 2008 at 6:32 AM
 Could you open the prop's .pp2 file and post the line with the path to the .obj file?
