Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Thanks for all this work, however, I'm talking infinite planes here not terrains... I can create the furrow using a terrain no problem... The idea was to use an infinite plane that way, it would just extend to the horizon... The whole thing is a study in perspective and the terrains just die out after a while and take up too much space.. Thanks for the help though..
Ok, I did that, and the way I did was the following: I took a volume land plane... That was my terrain... Then I duplicated that and made it into a long strip... I made the long strip negative and the terrain positive... Nothing.. I wouldn't get the long strip you're showing here... So you're telling me, make the land plane positive, make the long strip the water plane, make it negative, but transferring material of negative boolean?? Any info appreciated... Thanks...
Guys you need to remember that an infinite plane is INFINITE! You can't resize an infinite plane. What you will need to do is this. Create your volume infinite plane for the ground. Take a square boolean and strech it as far as you can see. Position the boolean to where it will cut the infinite plane. Set the plane to positive and the boolean to negative. Group them now. If you want infinte water, create an infinite water plane and place it just below the ssurface of the infinte ground plane! That will work! :)
Unfortunately Nak, although i appreciate the comments, that does not work, as you can see from my picture above... I did exactly that and it does not extend infinitely... At one point, the boolean dies... However, Canine managed to do it, as you can see from his picture.. and from his intructions, I can't get it to happen, and he has not elaborated on this since... (Don't be afraid to give me more info canine.. :) ) So, there is something that I'm not doing, cause I cannot get the one infinite plane to cut into the other infinitely plane, infinitely... So, if you can tell me why it's not happening for me, I would appreciate it Nak...
Canine, thank you for sending that... I probably have my work email as part of my profile and I won't get it till tomorrow... I appreciate it and will study it, cause honestly, I'm beginning to believe I'm a retard regarding this particular technique... I mean, I did it, but I was using a volume ground plane and a volume water plane... I'll try it with both water planes, one with the ground material and one for the cut... Thanks once again...
Hey Mikel, it's ok, you didn't come across as harsh... But for whatever reason, that technique is working for your, and Bryce is sticking it's tongue out at me cause look at my picture above and you see it dies after a certain point, whereas yours creates the right effect... But like I was telling Canine, I must retarded regarding this technique... I mean, there's so many other things in Bryce I can do and for whatever reason this keeps eluding me... Would it be ok to email me the bryce file?? My email is taledar@aol.com... This way I get to see how Canine did it and how you did it... thanks...
Let's say I want to create a long, infinite furrow in a plane... I take one plane, volume and make that the ground... Duplicate this.. I make it very thin horizontally, about the size of 10 feet wide and about 10 feet tall... I assign this infinite plane a negative value... Assign the ground infinite plane a positive value... I take the thin infinite plane and position it just slightly above the ground but extending deep into the ground... I group both of them... I don't get a long furrow that extends infinitely... Is there something I'm doing wrong, or does this not work with infinite planes??
