Tue, Dec 24, 7:23 PM CST
Subject: "For DAZ Studio only"... really?
giorgio_2004 ( ) posted Tue, 27 January 2009 at 5:17 AM · edited Tue, 24 December 2024 at 7:22 PM
I don't have DS so forgive me for the n00b question, but.... If I see "for DAZ Studio only" on a model, does this mean that there is absolutely no way to use it in Poser? No importing/exporting tricks or something like that?
I've seen a wonderful article for sale at DAZ, and it is at 50% off,  I was almost clicking my "add to cart" button when I noticed the small note.... ^_^
Giorgio
giorgio_2004 here, ksabers on XBox Live, PSN  and everywhere else.
JenX ( ) posted Tue, 27 January 2009 at 6:51 AM
what article is it?  it's easier to answer your question that way.
giorgio_2004 ( ) posted Tue, 27 January 2009 at 6:58 AM
It's the "My Contemporary View Home" house model. I did not want to name or link it, for obvious reasons. The code is ds_ac003b.
Giorgio
JenX ( ) posted Tue, 27 January 2009 at 7:02 AM
no, the reasons aren't obvious, since it's not actually any kind of violation to link to a product you have questions about.  You just can't post an advertisement for products.
nyguy ( ) posted Tue, 27 January 2009 at 7:05 AM
I think I can answer this, It looks like the file extension is a .daz, which mean was more than likely created in Daz Studio. I am unfamiliar with this vendor's work but all of his products look to be DS only.
Poserverse The New Home for NYGUY's Freebies
JenX ( ) posted Tue, 27 January 2009 at 7:06 AM
Attached Link: http://forum.daz3d.com/viewtopic.php?p=1656240#1656240
Nothing on the product page explains why, and, since I actually like the product, too, and wouldn't mind picking it up, I posted the question in the DAZ forum, since I have no clue.
giorgio_2004 ( ) posted Tue, 27 January 2009 at 7:14 AM
Quote - no, the reasons aren't obvious, since it's not actually any kind of violation to link to a product you have questions about.  You just can't post an advertisement for products.
Having read too many heated discussions on this subject (and not being so fluent with my English to easily identify advertisements), I preferred to be safe than sorry.
Thank you very much for posting the question in the DAZ forum!
Giorgio
geep ( ) posted Tue, 27 January 2009 at 7:42 AM
@ JenX
😕 When / if you get an answer over at DAS, would you please post the answer here, also.
Thanks. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
JenX ( ) posted Tue, 27 January 2009 at 7:52 AM
Sure!  The answer is, because it's in the proprietary .daz format, it won't work in Poser.  You CAN bring over the .obj's, but you won't get the morphs for moving parts.
geep ( ) posted Tue, 27 January 2009 at 7:59 AM
Thank you.  "That makes purrfect sense."  said the cat.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
giorgio_2004 ( ) posted Tue, 27 January 2009 at 8:00 AM
So no sliding doors, no removable roof.... that hurts. And I bet it would be necessary to re-apply the textures manually.
Too bad. It would have been a winner.... Thanks for your help, Jen!
Giorgio
nyguy ( ) posted Tue, 27 January 2009 at 8:02 AM
:m_coolsmirk:  Is that not what I kinda said, it is in DAZ format?
Quote - I think I can answer this, It looks like the file extension is a .daz, which mean was more than likely created in Daz Studio. I am unfamiliar with this vendor's work but all of his products look to be DS only
giorgio_2004 ( ) posted Tue, 27 January 2009 at 8:08 AM
You are right... the fact that there was a proprietary format in play was evident from the start. I was searching for a workaround, but it seems that there is none (or at least, not without spending other money for an expensive .CR2 converter).
Giorgio
nyguy ( ) posted Tue, 27 January 2009 at 8:11 AM
Quote - without spending other money for an expensive .CR2 converter).
Giorgio
is there a converter to change DAZ to Cr2?
giorgio_2004 ( ) posted Tue, 27 January 2009 at 8:13 AM
Seems so. Look at the thread posted by JenX, http://forum.daz3d.com/viewtopic.php?p=1656240#1656240. They are talking about it.
Morkonan ( ) posted Tue, 27 January 2009 at 8:14 AM
Quote - > Quote - without spending other money for an expensive .CR2 converter).
Giorgio
Apparently so: http://www.daz3d.com/i/3d-models/daz-studio-add/figure-setup-tools?item=8113&cat=341&_m=d
RHaseltine ( ) posted Tue, 27 January 2009 at 9:03 AM · edited Tue, 27 January 2009 at 9:06 AM
If you can run DS at all you could load and export as OBJ (and export the moving parts separately). I did't think there was an OBJ supplied - .daz scene files load the geoemtry from .dso files (the mesh, plus .dsv for the uvs and where needed .dsd for morph deltas) so as far as i recall the item is really DS only as it comes. I do have the item installed: the file list makes no mention of any obj files.
markschum ( ) posted Tue, 27 January 2009 at 9:46 AM
you can export it in pieces by using the visibility to control whats exported , then assemble in Poser by importing the pieces , setting the hierarchy and spawning a figure. Since the doors slide its a simple -tran or z-tran dial setting, no bend zones to deal with.
Any of the image maps should still work .
replicand ( ) posted Tue, 27 January 2009 at 1:34 PM
I think it also depends on the product. M4 displacement maps allegedy only work in Daz Studio because the images are TIFFs. (1) How difficult is it to convert a TIFF to a jpeg? Not very. (2) DAZ isn't the only program that supports TIFFs. The disclaimer should read "doesn't work for Poser".
Greywolf Starkiller ( ) posted Tue, 27 January 2009 at 1:50 PM
Umm, doesn't 'DAZ Studio Only' mean the same thing?
Greywolf
TrekkieGrrrl ( ) posted Tue, 27 January 2009 at 4:06 PM
 Hm. I must admit I think it's stupid to limit your models to one of the two "Posers" - it's not like DS can't read Poser models.
What would be the benefit of doing a DS only model?
I'm not a DS user at all so I may be missing something obvious. I have DS-savvy people helping me make my own products DS-ready to cater for both programs...
markschum ( ) posted Tue, 27 January 2009 at 5:04 PM
I believe some vendors are making stuff and they dont have poser.
Anyone know how to contact the vendor of that product. ?
I would be happy to do a poser conversion if he wants it done .
Dead_Reckoning ( ) posted Tue, 27 January 2009 at 5:09 PM
Quote - I think it also depends on the product. M4 displacement maps allegedy only work in Daz Studio because the images are TIFFs. (1) How difficult is it to convert a TIFF to a jpeg? Not very. (2) DAZ isn't the only program that supports TIFFs. The disclaimer should read "doesn't work for Poser".
Poser can use TIFF files , Semifieu offers a Free Python Script to use them and Cliff Bowman actually made MAT Pose files to use them.
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
Dead_Reckoning ( ) posted Tue, 27 January 2009 at 5:14 PM
Quote - I believe some vendors are making stuff and they dont have poser.
My question here is:
Are they using strictly DS?
Or are they fabriquating in a different 3D Graphics program such a Wings, Max etc etc.......
If so, doesn't those programs use Object files?
DS will only import and Obj file or a poser file, so WHY save everything strictly in DS Format?
Especially if Obj files were used ti create the product?
Thomas Jefferson
markschum ( ) posted Tue, 27 January 2009 at 6:41 PM
daz has its own native Daz studio file formats , if you export as obj you need to re-rig any figures .
replicand ( ) posted Tue, 27 January 2009 at 8:34 PM
Quote - Poser can use TIFF files , Semifieu offers a Free Python Script to use them and Cliff Bowman actually made MAT Pose files to use them.
Point taken, but since I was unaware of the Semifieu script, as far as I'm concerned, Poser doesn't accept TIFFs. Besides, how many noobs would know that off the bat (no offense to noobs)?
My favorite non-Poser renderer of choice directly supports and prefers TIFFs. So to say that files are DAZ only because they are TIFFs is a bit misleading, which was the point of my post.
Winterclaw ( ) posted Tue, 27 January 2009 at 9:49 PM
Trekie Girl
Quote -  Hm. I must admit I think it's stupid to limit your models to one of the two "Posers" - it's not like DS can't read Poser models.
What if the vendor doesn't have poser but does have DS?  That would be the simplest explanation for not making it usable in poser.  To bad there isn't any DS to poser export tools that can save things like morphs...
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
zai ( ) posted Tue, 27 January 2009 at 10:35 PM
I bring layered tiffs into Poser all the time. Works in 6 and 7 for me. That way I can change things on my layered tiff until I get my textures just right. Then I save them out as jpegs and re-apply as finals.
I don't know about the Mat files, since I don't usually save those and probably wouldn't for a final product, but they DO work in Poser. And I'm not using any special script..just hooking them up straight in the material room like normal.
Rendo Store | Freebies | RDNA Store
giorgio_2004 ( ) posted Wed, 28 January 2009 at 4:37 AM
Let me summarize..... Basically I should:
  1. Purchase the product  (obvious);
  2. Download and install Daz Studio (which is free);
  3. Load the product inside DS;
  4. Learn to use the visibility features;
  5. Export the various product parts in OBJ format (thus creating a bunch of separate OBJ);
  6. Import the required OBJs inside Poser;
  7. Go to the Material Room and re-apply the textures manually; (eventually converting them in JPG if they were in TIFF format);
  8. Save the various parts in a library for future use.
Am I right?
All these steps seem easy enough, except for #7 which seems very time-consuming.  Would the OBJs keep their UV maps?
Giorgio
stewer ( ) posted Wed, 28 January 2009 at 6:46 AM · edited Wed, 28 January 2009 at 6:49 AM
You don't need any special scripts to use TIFF files. Just load them like you would any other texture. Poser understands a variety of file formats for textures. There's nothing that requires JPGs.
JenX ( ) posted Wed, 28 January 2009 at 8:32 AM
Am I right?
Giorgio
So far, in order to use the product properly, yes.  And, yes, the OBJ's keep their uv's ;)
Dead_Reckoning ( ) posted Wed, 28 January 2009 at 9:24 AM
Quote - > Quote - Poser can use TIFF files , Semifieu offers a Free Python Script to use them and Cliff Bowman actually made MAT Pose files to use them.
I was refering to the M4 Tiff Displacement Maps that the poster mentioned.
Thomas Jefferson
Dead_Reckoning ( ) posted Wed, 28 January 2009 at 9:26 AM
So are you saying that the Vendor used the DS Primitives and built these scenes "Enitirely" in DS?
If not and those buildings were constructed in some other 3D App, then Why not offer the Object Files?
Thomas Jefferson
giorgio_2004 ( ) posted Wed, 28 January 2009 at 9:34 AM
I will believe such a thing when rivers will flow towards mountains and crayfishes will whistle like blackbirds  (Lawrence Block).   :laugh:
Not releasing at least the OBJ file seems a commercial suicide to me. A great loss of potential customers.
Giorgio
RHaseltine ( ) posted Wed, 28 January 2009 at 9:35 AM
Poser can read tiffs, and has long (perhaps always) been able to. However, before Poser 7 it couldn't read 16-bit per channel tiffs as used for the M4 displacement maps (in orer to avoid visible stair-stepping on large displacements), There was a trick in Poser 6 to combine two 8-bit per channel tiffs in the material room (since Poser could handle 16-bit per channel images internally) to achieve the same result, but that of course requires a completely separate set of files.
markschum ( ) posted Wed, 28 January 2009 at 10:15 AM
There are some utilities that will batch convert files  such as Fastone photo resizer.
http://www.faststone.org/FSResizerDetail.htm
markschum ( ) posted Wed, 28 January 2009 at 10:25 AM
Quote - "
Am I right?
Giorgio
You forgot
6.1. set hierarchy for objects belonging to house
6.2 set pivot points for swinging doors (sliding will be ok)
6.3 create a figure for future use
6.4 Rename dials as open/close instead of x-translate etc
6.5 set limits on moving parts
6.6 set forcelimits 4 so limits always in force
6.7 Hide any translate or rotate dials that dont get used
do step 7
7.1  save figure again
and then ya dont need step 8 ( what a saving :)  )
:woot::woot::woot::woot:
(* insert eveil laugh here bwahahahaha)
TrekkieGrrrl ( ) posted Wed, 28 January 2009 at 4:18 PM
Quote - Trekie Girl
Still as it was asked is the MODEL made in DS? Not likely. DS isn't amodeling program and as such, the OBJ files ect must have existed on some point of that product's life.
I just don't understand why anyone would cut himself off from the large market that is Poser. But that's just me.  Yes he might not be able to rig the thing for poser without poser.. but at least suppluy the obj's.. that's not hard to do...
Dead_Reckoning ( ) posted Wed, 28 January 2009 at 4:36 PM
Quote - > Quote - Trekie Girl
I am pretty certain that when those products were released, there wasn't any rigging tools available for DS.
I am agree with you 100% on cutting out the poser market.
As soon as I noted that, No Sale came up.
Thomas Jefferson
