Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 2:39 pm)
Is this with the default morph, or have you spawned a new set of morph targets in some way? This kind of thing can happen when you've used a "morph" that is actually a bone scale change, and most scripts that auto-spawn morph targets on all body parts will filter out the bone scale change.
Figure Height doesn't work with DAZ figures for sure, other figures by EF "maybe".
I kinda thought it was fallout from my own playing around, but no. This happens with the default V4, even with not so much as Morphs++ applied.
I wonder what Figure Height actually works with if not Olivia. Maybe just the older EF figures. Kinda frustrating, because it's really tough (impossible) to try to change torso length.
______________
The Figure Height was made for, and works with, the good old Poser4 characters (also known as Posette and Dork) . ^_^
Quote - I kinda thought it was fallout from my own playing around, but no. This happens with the default V4, even with not so much as Morphs++ applied.
You probably have a fried install of V4. If you are OK with completely removing, then try this:
Run the uninstaller for V4 if you installed it
Delete the V4 CR2 in FiguresDAZ People
Delete the RuntimeLibraries!DAZVictoria 4 folder
Re-download V4 from DAZ
Install the newest download
If you don't actually remove the RuntimeLibraries!DAZVictoria 4 folder, it can happen that some junk is left in that folder that can screw up your reinstallation. Hope this helps.
On an unrelated issue - does figure height resizing (Figure > Figure Height) in Poser work for anyone? Whenever I try to use it, I get grossly oversized hands... or does it only work for Smith Micro figures? Hmm... never tried it with those.... EDIT: Just tried with Olivia G2: makes an even bigger hash of the figure than with V4.
I'm using Poser Pro.
______________
