You can squeeze an extra GB of RAM out of XP 32 bit by using the /3GB startup switch in boot.ini. Poser 7 then can use up to 3 GB of RAM. That may be enough to render your scene.
The /3GB switch doesn't always work. A lot depends on how your graphics card wants to be addressed.
Switching to a 64 bit OS (either VIsta 64 bit or XP Pro 64 bit) will expand the amount that Poser 7 can use to 4 GB, for both Poser.exe and FFRender.exe.
If you have Poser Pro, FFRender64.exe will kick in if you render in a separate process on a 64 bit OS, and then the maximum addressable memory will be something like 128 GB.
A couple of days ago I rendered a scene that took up to 16 GB of virtual memory during the render. Quite a lot of swapping, since I "only" have 8 GB of physical RAM in the system, but the render finished alright, after 2 days. Sadly, the results weren't what I wanted...
32 bit OS can use 4gb ram. I have 4gb ram on my computer and so does my tech friend. He just installed it in my machine and bam. I use xp pro. I have 512mb graphics card and can usually render a scene with a good few figures in it. Last scene I did that was major had 5 figures in.....took 4 hours to render and I played world of warcraft at the same time.
"I didn't lose my mind, it was mine to give away"
How much XP 32 bit "sees" depends on the chipset and on the BIOS capabilities and settings.
One of my mainboards had the option to remap I/O addresses to above the 4 GB boundary, and XP 32 bit "saw" a full 4 GB of RAM.
In other systems it may be 3 GB, or 3.25 GB, or 3.5 GB.
This number is the total amount of RAM that the OS can assign to applications.
The other limit is how much memory a single application/process can get. In normal circumstances, that's 2 GB per process. When started with the /3GB switch, it's 3 GB per process - if the process is able to use it. Poser 7 is compiled with the LARGE_ADDRESS_AWARE switch, so it will be able to use that extra GB. Poser 6 and older, and DAZ|Studio, are "pure" 32 bits applications that will only use 2 GB of address space, even if there is far more available.
Standard 32 bit applications will still be limited to 2 GB on a 64 bit OS.
LARGE_ADDRESS_AWARE applications will be limited to 4 GB on a 64 bit OS
64 bit applications will be limited to 128 GB on XP Pro 64 bit. I don't know about Vista 64 bit, Windows 7 64 bit or Linux, but it won't be less than 128 GB.
The BIOS will show what's actually there, since it's not limited by an OS.
Instead of playing with the adaption threshold, you may try a lower bucket size, higher shading rate and/or lower number of processes. The adaption threshold will just tell Poser when to switch to a lower bucket size, but Poser may ran out of memory before that check kicks in.
For Poser 6 I switched the adaptive bucket size off completely as that would allow Poser to use more memory... Didn't try if Poser 7 has the same "problem", but you can try switching it off and see if it works, too.
Poser allways generates hi-res textures into " C:Documents and SettingsAdministratorLocal SettingsTempPoser ProPoserTextureCache " ( if you have windows xp ) , you got that error only when your hard drive is fully ocupied. Go to TOOLS- VIEW- SHOW HIDDEN FILES AND FOLDERS and then go to " C:Documents and SettingsAdministratorLocal SettingsTempPoser ProPoserTextureCache " check PoserTextureCache folder, you will se then every time you do renders new files will apear there. Few scene is enought to reach to 10 gb of hard-drive. Just watch allways PoserTextureCache and you will see what I am tallking about. Also see my image please.Sorry, I`ll post new message with img.
PS: Sorry for my english.
Quote - You can squeeze an extra GB of RAM out of XP 32 bit by using the /3GB startup switch in boot.ini. Poser 7 then can use up to 3 GB of RAM. That may be enough to render your scene.
Reviving this thread...
How does this work? Do I simply add a line in Boot.ini saying /3GB startup or what?!
Lady, do that:
1 right click on " my computer " and " properties "
I got an error message saying there wasn't enough memory to render my pic (even though I have 4GB ram and 512MB video) It sugested I render in a seperate process and/or enlarge the adaption threshold. Well rendering in a seperate process does not work at all, so I'm wondering what a good adaption threshold would be.
