Sat, Feb 15, 5:00 AM CST
Subject: Wet Streets in Vue
mojoDallas ( ) posted Tue, 24 February 2009 at 2:27 PM · edited Fri, 14 February 2025 at 6:11 PM
Looking for some help.  What is the best techinque for making pavement appear to be wet?  Is there a tutorial out there that talks about doing this?
Hardware:  Cyberpower PC,  2 - i7-3970X CPU @3.50 GHz (12 Total Cores), 32 GB RAM, 2 - GeForce GTX 690 $GB Video Cards, 2 - Viewsonic V3D231 23" Monitors
Software: Poser Game Dev, Vue xStream 2014, 3ds Max 2014, Maya 2014, Mudbox 2014, Corel PaintShopPro, Unreal Engine 4, Iron Python
Rutra ( ) posted Tue, 24 February 2009 at 2:32 PM
IMO, the main ingredients are shiny highlights and a little bit of reflection. I don't know of any tutorial.
cyberzen1 ( ) posted Tue, 24 February 2009 at 3:26 PM · edited Tue, 24 February 2009 at 3:27 PM
If it's a night scene, I often actually use a shiny metal!!!! I will often add some bump to it though- sometimes a touch of blurred reflection and for pudddles I'll make it a mixed material plus a distribution map. I usually change the color too, to a dark grey.
chippwalters ( ) posted Tue, 24 February 2009 at 4:57 PM
 It really depends on how wet you want it to be. Standing puddles are as reflective as mirrors. Damp pavement is only slightly reflective. You can try adding a 'puddles' layer to an existing material, then making it reflective and controlling the alpha and reflectance channel with a noise node. That should get you started.
Here are a few links to some renders I did using reflective ground treatments, maybe they can provide some inspiration:
[ http://www.renderosity.com/mod/gallery/index.php?image_id=1808082
](http://www.renderosity.com/mod/gallery/index.php?image_id=1808082)[http://www.renderosity.com/mod/gallery/index.php?image_id=1837070
](http://www.renderosity.com/mod/gallery/index.php?image_id=1837070)[http://www.renderosity.com/mod/gallery/index.php?image_id=1777015
](http://www.renderosity.com/mod/gallery/index.php?image_id=1777015)[http://www.renderosity.com/mod/gallery/index.php?image_id=1241905
](http://www.renderosity.com/mod/gallery/index.php?image_id=1241905)http://www.renderosity.com/mod/gallery/index.php?image_id=1037758
mojoDallas ( ) posted Tue, 24 February 2009 at 8:16 PM
Thanks for the tips.  I like the idea of adding a puddles layer either through a distribution map or just by mixing materials.  I also will try the metal for relectivity.
GaryMiller ( ) posted Wed, 25 February 2009 at 1:44 AM
Depending on the angle in which you are viewing, you want to add reflection and add highlights.  I have created several images with wet pavements and this method definately works well.  To get the best results, you want to have a low bump setting otherwise your reflection and highlight setting will get lose.  Remember: Low bump unless you want it to be slick like glass.
silverblade33 ( ) posted Wed, 25 February 2009 at 4:33 AM
tutorial on this in 3D world a while back, I have it in my folder of saved pages for Vue ;)
used a layer, distribution function as folk say, with a rainbow colour for oil slicks too
