Tue, Feb 18, 4:16 PM CST
Subject: Needed: Imported Bryce sized box
dyret ( ) posted Sun, 14 December 2008 at 2:32 AM · edited Mon, 17 February 2025 at 5:28 PM
Pumeco tells me that I can't use the bryce box with the prorender system. So I tried to import the daz studio one. That doesnt fit the bryce primitives. Any tips?
TheBryster ( ) posted Sun, 14 December 2008 at 6:18 AM
You might want to enlarge on your query?
ThunderStone ( ) posted Sun, 14 December 2008 at 6:19 AM
Have you try to import via Daz Studio button the box?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
dyret ( ) posted Sun, 14 December 2008 at 1:32 PM
the bow primitive in daz studio is a different size than the bryce primitives. for example: if i set up a cylinder in bryce  that is 20x20x20 the daz box with the same masurments will not fit the bryce cylinder
dvlenk6 ( ) posted Sun, 14 December 2008 at 2:11 PM · edited Sun, 14 December 2008 at 2:14 PM
20.48 BU (Bryce Units) = 0.401569 meters for a D|S primitive brought into Bryce via the D|S link.
Friends don't let friends use booleans.
pakled ( ) posted Mon, 15 December 2008 at 11:58 AM
...unless they're talking about a very old tutorial that showed you how to map a (I think) Bryce 4 box on the outside of a cube...is that it? It might have been Brycetech, around that era
dyret ( ) posted Sat, 20 December 2008 at 5:02 AM
sorry i have been so long without any reply. the trouble with the daz box is that its calculated differently. that means that if i try to calculate its position in bryce it will be wrong compared to the other bryce primitives size and position.
TheBryster ( ) posted Sat, 20 December 2008 at 5:04 AM
You know? I'm not really getting a handle on what your problem is. If you import something into Bryce you can re-size it in Bryce. If at the time you import, your object is the wrong size, what is your problem?
dyret ( ) posted Sat, 20 December 2008 at 11:07 AM
daz studio box, bryce cylinder. both 20x20x20 bryce units
dyret ( ) posted Sat, 20 December 2008 at 11:11 AM
ThunderStone ( ) posted Sat, 20 December 2008 at 11:57 AM
AND???? Like TheBryster said, What's the problem?
dyret ( ) posted Sat, 20 December 2008 at 12:01 PM
as my picture shows 20 daz studio units are smaller than 20 bryce units. that means i'm not able to do the right calculations
but... i'll not bother you guys any more
TheBryster ( ) posted Sat, 20 December 2008 at 12:59 PM · edited Sat, 20 December 2008 at 12:59 PM
From your picture I can see that there are differences, but by using the attributes grid [A] this is easily corrected in Bryce.
Rayraz ( ) posted Sun, 28 December 2008 at 6:05 PM
ok, i think i get the problem, the cube of 20x20x20 has different boundaries then the 20x20x20 cilinder, while you would expect the edges to meet, since.. they're the same width.. thats strange indeed.
If you size 2 primitives the same size, you'd expect them to have the same size, i totally agree.
However.. the default bryce cube isnt 20x20x20, it is actually 20.48 x 20.48 x 20.48... might not look significant to add the decimals but it is :) maybe thats the prob?
try makin the cube it 20.48x20.48x20.48.. does that solve it?
(_/)
dyret ( ) posted Tue, 30 December 2008 at 1:12 PM
no it doesnt solve it. im sorry for not beeing able to explain better. i will have to use other methodes.
ThunderStone ( ) posted Tue, 30 December 2008 at 6:42 PM
Quote - no it doesnt solve it. im sorry for not beeing able to explain better. i will have to use other methodes.
dryet,
I think I might have a solution to your problem...
Try this...
  1. Import the cube from DAZ studio via the button on the create bar (with an S on it)
  2. Create a normal  cube from with in Bryce.
  3. Select the Bryce Cube.
  4. Edit the material to your liking.
  5. From the edit drop down menu, click on "copy matrix".
  6. Select the DAZ Cube.
  7. From the edit drop down menu, click on "paste matrix."
You will see that the DAZ Cube has changed.
Go ahead and try it... I'll post the screen cap in a bit.
TS
ThunderStone ( ) posted Tue, 30 December 2008 at 6:52 PM
Here's the screen cap:
calyxa ( ) posted Tue, 30 December 2008 at 7:31 PM
it's still visibly smaller there.
______________________________________________________________________________________
Check out my Elemental Hexagons deck, created with Photoshop, Bryce, MojoWorld, and Poser
ThunderStone ( ) posted Tue, 30 December 2008 at 7:55 PM
You got to try it in person. Don't rely on the screen cap as I am not so good with placements. I just wanted to show it could be possible.
calyxa ( ) posted Tue, 30 December 2008 at 10:03 PM
I was going to before I posted, but I've never used DAZ Studio and when I clicked the 'S' thing, I got the rainbow spinning beachball of death, so I gave up.
dyret ( ) posted Sat, 03 January 2009 at 6:09 AM
ok. thank you ALL for all the replys. Sorry to say none of them solved MY problem. LOL. I'm hoping to make a box wich I can use. Happy new year everybody!
FranOnTheEdge ( ) posted Sun, 15 February 2009 at 7:33 PM
One other idea: you could go to wings3d, make a cube and a cylinder in there... and then do whatever it is you want to with them after importing them to Bryce.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
dyret ( ) posted Wed, 18 February 2009 at 2:27 PM
Yeah, I hope I'll dare to try out wings some day. lol.
TheBryster ( ) posted Wed, 18 February 2009 at 2:52 PM
Heresy.
dyret ( ) posted Thu, 19 February 2009 at 9:42 AM
Oh no Fran. We got found out. Quick. Hide!!!!
TheBryster ( ) posted Thu, 19 February 2009 at 10:34 AM
(Flicks feather duster over the comfy chair....)
FranOnTheEdge ( ) posted Thu, 19 February 2009 at 7:14 PM
It wasn't me - I was never there... (insert smilie with halo here)
Fran's Freestuff
pumeco ( ) posted Fri, 20 February 2009 at 8:49 AM · edited Fri, 20 February 2009 at 8:51 AM
Just spotted this!
dyret, the good news is understand exactly what your problem is, the bad news is that I'm not sure it's fixable.  I've never bothered with it before because I generally just import everything into Bryce for rendering so I've never needed to match the scaling to Bryce primitives.
I'll try to find a solution.
EDIT: Great to see you playing with Pro-Render ;-)
FranOnTheEdge ( ) posted Tue, 24 February 2009 at 5:06 PM · edited Tue, 24 February 2009 at 5:06 PM
Hmmm... @ Bryster
Fran's Freestuff
dyret ( ) posted Sat, 07 March 2009 at 11:21 AM
Thanx pumeco. finaly someone understand. puh...(norwegian PHEW)
pumeco ( ) posted Sat, 07 March 2009 at 1:18 PM
Good job you bumped the thread, I'd already forgot about it :biggrin:
I'll take a look.
dyret ( ) posted Sun, 08 March 2009 at 3:37 AM
Pumeco: I'm glad you understand my problem. Big sigh of relief from me. I'll have to look into wings. I'm not skilled enough to make the things I want in bryce. So Bryster, gather the the logs and have the matches ready. :biggrin:
TheBryster ( ) posted Sun, 08 March 2009 at 7:34 AM
FranOnTheEdge ( ) posted Sun, 08 March 2009 at 2:29 PM
Why not import both a box and a cylinder?
What do you need them for anyway? - there might be another way to get what you want and simply bypass the box and cylinder altogether.
Fran's Freestuff
pumeco ( ) posted Tue, 10 March 2009 at 2:00 PM
Well, I gave it a bash last night but I'm sorry to say I can't import a cube without it gaining that buffer space 'round it, sorry mate.  I can't even imagine why it's set up like that in the first place, it goes against the ability to line-up stuff on the grid, and Bryce is generally well set up for that sort of thing.
dyret ( ) posted Sat, 14 March 2009 at 7:30 AM
thats the weird thing about it. and also bryce default measures. 20.48??? why??? oh well. thats life. i'll have to become a herretic(or heretic?) thanx for the time pumeco.
