Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
More: the same problem in David (not really surprising) - no similar problem in Sydney or Simon (surprisingly, Jessi is OK here too).
For some reason in the past few days I've been getting all hot and bothered whenever I read your forum posts. I'm going to have to try to ignore them... sorry.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
I'm pretty convinced now the rig is just bugged and I'm not going to get anywhere trying to work around it - while I guess I could noodle around in the rig and try to fix it for myself, the result wouldn't distributable anyway. Is there some fix that's in common circulation?
Thing is.. from your pic I can't see the problem. You're saying the kleft and right shin aren't symmetrical.. but this only shows one of them. How much are they off? A lot or a little?
It seems weird that if this is a major problem, nobody would have found/made a fix for it by now :) After all there are lots of shoes ect out there for the characters (Oh speaking of shoes: THANK YOU for that awesome shoe tutorial! I'll have to see if it's adaptable to Hexagon ^_ ^)
Quote - Maybe Blackhearted knows more. He did one of the best SP3 characters - Irina 2.0.
Flat shoes only, I suspect he ran into a similar problem and came to the same conclusion.
Quote - Flat shoes only, I suspect he ran into a similar problem and came to the same conclusion.
:P
i actually did try to make high(er)-heeled boots but was having issues conforming them, this may have been a factor.
at the time i didnt know why things werent working right, just that they werent - i just went back and made flat heeled boots.
thank you!
Hm this is interesting. So there's really no heels for SP3? (or David for that matter.. he COULD walk in boots with a heel...)
Now.. I don't know how these are grouped, if you have a left and a right shoe or both shoes loads as one, I've seen conforming shoes done both ways... IF they load as one, perhaps you could split them and conform them as two totally separate things (mentally think of them as a shoe and a glove that just happens to be on the foot LOL)
Dunno if it would help but it's certainly weird, and very interesting. Also that no one has apparently pinpointed the problem before.
How about Aiko3? Isn't she a sort of SP3 with a morph? Because IF the problem is solved in Aiko you might be able to use her as a donor for the JP's and transfer them to SP3.
I wouldn't say there are "none", but I have seen few, and I only own the one pair. Since this is my own model, it's grouped however I want it to be and could be split up into separate files if that would help, but I don't think it really would. The problem appears to be that SP3's bone - the character's bone - is skewed or scaled in some way that is not obvious. I guess I could manually rig each shoe, but - well - that isn't worth my time for a model that at best would have been handed around as a freebie anyway.
Not real excited to model shoes for A3, although I wouldn't mind for Ingenue V3/Glamourous Vickie (they're actually ready made for heeled shoes, a bit over the top).
You are an experienced operator Pjz so please don't take my suggestions in the wrong way...just trying to help.
I've had the Poser Blank rigs do strange things before as well. Then I create my own BlankCR2 for that figure and it all works just fine. Most times I delete the IK's, but sometimes I need to keep them in otherwise things go wonky.
With all that said I fear that even if you did have a good Blank CR2 to go from it will still be screwed up as it is just trying to do what the figure rig is doing, and since the figure rig isn't sure what it wants to do at this point (not symetrical) then...???
Just for sh*ts and giggles trying conforming them with the IK's on, see what happens. That's pretty much what I do when up against the wall, I'll just try stuff to eliminate that option from my trouble shooting...more or less throw things against the wall to see if they stick.
Good luck to you!
I'm not very interested in trying things at random when the character's rig is obviously a bit screwed up (mismatched falloff zones e.g.). If it wasn't important enough to DAZ for them to fix one of their own flagship characters at some point during the past several years, who am I to go against the trend?
Just as an experiment, I attempted to correct Steph 3’s rig by using Symmetry/Right Leg To Left Leg and checking ‘yes’ on the ‘Do you want to copy the joint zone’s setup also?’ box. This simply will not work on Steph 3’s shins. The falloff zones remain asymmetrical. The fact that it should work but it doesn’t is another example of how messed up Poser Setup can be.
I don't have any immediate answers for you, re: high-heeled shoes, but to answer your question - yes, SP3's rigging is horked (IIRC, V3's is somehwat off as well). In fact, it's not just her legs/feet - if you check the 'center' of each joint, you'll find that her neck (? head? chest?) are not exactly at 0.0 on the X axis either. It was a royal pain in the you-know-what when I was rigging the SP3 clothing (stockings and lingerie).
Daz is pretty sloppy about this with some figures, unfortunately.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
When I was making stormchaser boots for V4/GND, I had issues with this too. Finally I made a morph to squeeze the feet/legs into the boots.
Not only is it not symmetrical, but there's some sort of a rotational shift to the shins between the original mesh and what you get when you use the cr2 (developers blank or not).
It all boils down to a lot of fiddling around to fit boots.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Oddly, I didn't have a problem rigging boots for V4. I don't think the problem is the same for that figure, even though the rig is still not symmetrical (at least in Poser). Currently working on a set of boots for M4, I'm optimistic about those since M4's rig appears to be symmetrical around that area.
Sorry, if it came across that way, I wasn't suggesting that the problem is the same with SP3 and V4. I never rigged SP3, so I wouldn't know.
I saw you mentioning in the first post that the problem you were seeing in SP3, you were seeing in V4's rig too.
PJZ's first post:
*Is it just me or is SP3's rig borked? The joint parameters for left and right shins are not symmetrical (see pic). I've been trying to rig a pair of shoes this afternoon and having a lot of problems, I'm pretty sure this is why. This pic is of the actual character figure's shin Bend parameters, but the problem appears to be present in the "BLANK" figure (rigging bone donor) as well. Have other people noticed this?
edit: I see the same thing in V4's shins. *
yurs?
BadKittehCo
and product support
Yeah I hear you - I'm saying the problem appears to be much worse with SP3 than it is for V4. If you want to, you might compare the boots I included with my last freebie and see how their rig looks next to yours. I got this to work a couple of times in a row for V4, but for SP3 I never got a decent joint arrangement. I can see that the V4 rig is also not symmetrical, but for whatever reason it didn't cause the same degree of trouble when rigging shoes for her.
Quote - Yeah I hear you - I'm saying the problem appears to be much worse with SP3 than it is for V4. If you want to, you might compare the boots I included with my last freebie and see how their rig looks next to yours. I got this to work a couple of times in a row for V4, but for SP3 I never got a decent joint arrangement. I can see that the V4 rig is also not symmetrical, but for whatever reason it didn't cause the same degree of trouble when rigging shoes for her.
Gotcha :)
I've been using the DAZ's figure setup tools more and more... for the JCM mostly at the moment. Can't wait to try it on a rig... but that's probably few weeks down the road. If you;re curious, I'll share my experience(s)... while they're fresh. I don't do enough of it to have it memorized later on... One rig every two months doesn't cut it.
yurs?
BadKittehCo
and product support
I'm interested to see how that works, sure - probably would be useful to everyone to have a little pictorial walkthrough of it in its own thread.
Hm but IF It's a Gimbal Lock problem, shouldn't all Poser figuressuffer from it? Which apparently they do not.
Will, I'm absolutely not saying it isn't so, actually it sounds like a very good explanation.. I just wonder why some Poser characters seem to suffer from this more than others.
And especially that the native Poser figures has less problems.COULD it be (and PLEASE..this is not a DS vs Poser debate by any means) that Daz figures are geared more towards DS while Native Poser figures are .. well meant for Poser?
And how are they rigged differently?
It's interesting for me. Purely from a curious point of view :)
I think it more likely, the DAZ figures are not tested as thoroughly in Poser - they're definitely marketed for Poser "loud and proud".
I took a look at the joints of SP3 vs. EF Sydney (who does not show this kind of problem) and the only thing that really jumps out as different is that the DAZ figure's endPoint, origin and orientation values are carried out to much further decimal point precision (7 places) and some values are small enough that they probably should have been simply zero'd (e.g. -0.008something).
A couple of values in particular in the jointX block for the SP3 shin (where the falloff zones are described) are pretty ominous:
0.0619999 8.45394e-005 0 0
-1.50849e-011 0.167996 0.00151762 0
-9.73378e-014 0.00108402 -0.119998 0
I know that's scientific notation, I wonder if it's being interpreted correctly by Poser.
I don't think it's a coincidence that, in Sydney's buttock bones, there are similar very tiny non-zero values for some of the jointX (falloff zone) parameters:
0.0718686 0.0541607 **-0.000383462 0
**0.0611069 0.312 8.3968e-005 1
Surprisingly, Simon's rig appears to be OK - I would have thought problems similar to Sydney's would manifest, but nope. While Simon's joint params do contain some very small values, none are smaller than e-07 unless they are simply zero. However, this isn't really out of line with Sydney's joint param values (none of hers are smaller than e-06 unless they're zero). Maybe it's that one specific joint param is of a data type that is too small to contain the value recorded in the CR2 (insufficient precision), and by luck, Simon is OK while Sydney is not.
As an experiment that I shouldn't have wasted my time on, I tried rounding most of the values in Sydney's JPs for the screwed up area - this did not help or affect the problem, so it doesn't seem to be related to interpreting the precision of these numbers correctly. I have no real idea why this problem pops up consistently for one figure and not for another. I'm also seeing the retarded tumbling falloff zones behavior, so it can't even be fixed manually, it's simply impossible to get the falloff zones to line up even when manually typing the correct values in each field - simply selecting a field in Parameter Dials causes the falloff zone to move!
More wasted time: I slapped SP3's rig around until it appeared completely symmetrical and turned that into a pose. This doesn't do anything useful however, because a conformed figure still produces asymmetrical deformations. Somehow, one of the leg bones is "upside down" or "backwards", or it is being interpreted as such by Poser anyhow (is there a difference?)
At any rate, I cheated and got my goddamn SP3 shoes rigged any damn way, I twisted the character's toe -9 degrees (that's how badly off this is).
SP3’s shin falloff zones appear symmetrical when viewed in Daz Studio. Also, her foot bones are located separate from the toe bones and point out horizontally above the foot geometry. In Poser, the foot bones have snapped to the toes and the shin zones are out of whack.
Well, I don't think DAZ is going to put a disclaimer on figures with this kind of problem e.g. "This figure doesn't work correctly in Poser, sorry". I guess I could spend $300-400 on D|S to try to get it close to Poser in function - well, no.
Yeah, Poser rules and all that. I just wish they'd fix the Setup bugs. One of these bugs is that a bone will always snap to its first child.
Oh, I'm not saying Poser's the perfect app. It's not even a very good app in terms of interpreting its own content. I'm just not eager to sink several hundred bucks into D|S to get a maybe better Poserish app - I guess I'll stick to the figures that are rigged correctly (or at least, less incorrectly).
That looks good. The one thing that worries me is that when I start rigging for Poser in Daz Studio, Poser might not be able to correctly interpret the exported cr2s.
Yeah, that seems to be the root problem here, at least with SP3 (no idea why EF let Sydney out the door with this problem).
I did some heels for SP3 a long time ago.... I called them "porn shoes".,, they are close to 5" heels
I'm at work so I can't post any pics of them. I didn't have a really bad time getting them to work. One thing I found is that you need to make sure all of the IK statements are deleted from the cr2 and that IK is actually off.
Ed
Yeah I checked that also (removed IK from the rig), didn't help with these. They just do not behave the same in Poser as they do in DAZ|Studio.
What version of Poser was this?
edit - is the toe actually rigged separate from the foot there? I wouldn't think so for the platform shoe, how about the boot at the bottom?
My Freebies
